Sushi Home project
Description
Home domotics demo project using a Sushi Board, code in Micropython on SushiPython framework.
Features
- Heater system thermostat: control a relay output connect to heater system
- Local control on physical interface
- Remote control by SMS
- Main power loss/return detection
- Alert by SMS
- Get status by SMS
Version : v1.0.0 - 2026-01-11
Video demo : Sushi IoT on instagram
Source files
- sushi_home.py : main program script file.
- sushi_home_config.py : sushi IoT configuration e project settings
Instructions
Start guide
- Assemble the Sushi Board (see hardware components section).
- Download and flash the latest [SushiPython IoT Firmware](https://github.com/sushi-iot/sushipython/releases) onto the board.
- Connect the ESP32DevKitC board to your PC by the USB connector (or use WebREPL if you prefer).
- If you are new to MicroPython see this [basic MicroPython guide](https://sushi-iot.github.io/sushipython/coding/).
- Transfer the '.py' project source files (see source files list) to the board using your favourite MicroPython interface.
- Edit these settings in "sushi_home_config.py" :
- "MODEM_ENABLED_NUMBERS" : phone numbers enabled to send/receive SMS
- "modem_sim_sms_center" : operator SMS center number (necessary to let the modem manage SMS messages)
- "modem_sim_pin" : your SIM pin
- "modem_apn" : SIM operator APN
- "modem_user" : SIM operator user (if required)
- "modem_passwd" : SIM operator password (if required)
- Run the main script file.
- From the REPL output it's possible check the script execution output.
- To interrupt the script execution and return to the REPL prompt press "CTRL+C" (as you can see from the py code to manage all the tasks the script run a main loop).
Testing the project
- Heater system
- When the heater must start, it switches on the relay output. This is visible from the red LED on it.
- By scrolling the user menu, enter "Thermostat". This menu is added by this project. From here it is possible to set the heater target temperature.
- From the "DIAGNOSTIC" menu it is possible to check the actual temperature read from the sensor.
- It is possible to set the target temperature by sending an SMS with the text "#SET-TEMP=...", for example "#SET-TEMP=22.5". Note: the source number must be included in the `MODEM_ENABLED_NUMBERS` list.
- By plugging or unplugging the main power supply, the script sends a status SMS message informing about the change to every number defined in the `MODEM_ENABLED_NUMBERS` list.
- SMS status monitor
- It is always possible to check the system status by sending an SMS with the text "#STATUS?". The script replies only to this number (if it is included in the `MODEM_ENABLED_NUMBERS` list) with a status SMS.
Hardware components
This project uses a full Sushi Iot Board kit.
All details on Sushi Board can be found on [Sushi-Iot-Board Github repo](https://github.com/sushi-iot/sushi-iot-board).
Overview
[Sushi IoT on instagram](https://www.instagram.com/sushi_board_iot/)
Hardware connections table
For test/demo purposes, this project does not require any external hardware.
In a real application, the heater system must be connected to the relay output and an external DS18B20 cabled temperature sensor is recommended to measure the environment correctly (for test purpose by default is used the onboard DS18B20 sensor).
Resources
Sushi-Iot-Board
SushiPython IoT Firmware download
Online coding manual
SushiPython IoT project overview
SushiPython microPython quick reference
Marco
