Introduction
Despite being a vital component of everyday operations in workplaces, schools, and universities, attendance tracking is frequently tedious and subject to human mistake. With automation and real-time data logging, the Arduino UNO R4 Wi-Fi Based RFID Attendance System provides a sophisticated solution.
This technique makes tracking attendance easier by utilizing RFID (Radio Frequency Identification) technology. Every student receives and RFID card, which the system stamps as "Present - On Time" if it is scanned within the first ten minutes of powering up. Students who do not scan are immediately marked absent, while those who scan after ten minutes have their status changed to "Present - Late."
Additionally, the system has a teacher's master card that, when scanned, shows the attendance summary for every student who has enrolled on a 20x4 I2C LCD screen.
This project combines automation and electronics to provide a practical smart attendance solution that is perfect for:
- Automated attendance without manual roll calls in schools and universities
- Training Programs and Workshops: Simple Ways to Monitor Employee Presence
- RFID-enabled rapid check-ins for seminars and events
- Future enhancements could include syncing with cloud databases, enabling online data logging to Google Sheets and other platforms or integrating Wi-Fi access with the Arduino Uno R4 Wi-Fi built-in module.
How This System Works
The Arduino Uno R4 Wi-Fi initializes the LCD and RFID module when it is turned on. The active attendance window is indicated by the system starting a 10 minute countdown timer.
Here is a detailed explanation of how the system works:
1. System Initialization: "Ready for Attendance" is the greeting that appears on the LCD when the system is powered on. At the beginning of the session, the Arduino logs the current time.
2. RFID Tag Scanning: The Arduino compares the Unique Identifier (UID) that the RC522 module reads from a student's RFID card with a list of registered UIDs that has been stored.
3. Update on Attendance Status:
- The student is marked as "Present – On Time" by the system if the card is scanned within ten minutes.
- "Present – Late" is recorded if the scan is done after ten minutes.
- Once the teacher's card has been scanned, students who do not scan are immediately declared absent.
4. Teacher Summary Card: The attendance summary is activated by the teacher's RFID card. The LCD screen successively displays each student's name and attendance status (absent, late, or on time).
5. Wi-Fi Extension (Optional): Real-time remote attendance monitoring is made possible by the Arduino Uno R4 Wi-Fi, which allows data to be subsequently transmitted to cloud servers, online databases, or even Google Sheets.
By doing away with the inconvenience of manual attendance sheets, this solution guarantees accuracy, transparency, and efficiency.
Taking the Project to the Next Level - With JUSTWAY
Even while your Arduino attendance system functions flawlessly on a breadboard, it might not seem professional when you show it off at investor demos, tech fairs, or competitions.
Presentation is important, and JUSTWAY helps with that.
JUSTWAY assists you in turning your do it yourself project into a high-quality prototype that feels and looks like genuine product that is ready for the market.
Why JUSTWAY is the Perfect
Rapid Prototyping
- 24 hour production tracking
- Real-time production tracking
- Perfect for students and makers on tight deadlines
CNC Machining (Aluminum 6061 / Stainless Steel 304)
- Delivers ultra-precise, strong enclosures
- Gives your project a premium industrial-grade body
Sheet Metal Fabrication
- Laser-cut and CNC-bent metal sheets
- Options for powder coating finishes
- Ideal for casting your attendance system elegantly
Injection Molding
- Transition from prototypes to mass production
- High-quality, custom-designed plastic enclosures
Urethane Casting
- Perfect for...
Rohan Barnwal
ElectroScope Archive
ammarbhayat28
zgezt91
kamalkedin123
