Supplies
1. The ESP32 Display-5.0 Inch is used as the main control board to control the infrared module and read temperature and humidity information from the sensor. It can also display the user interface designed with LVGL on the screen for human-machine interaction.
2. The Crowtail-AM2302 Humidity & Temperature Sensor 2.0 is used to help me obtain the temperature and humidity information of the surrounding environment, which is then transmitted to the main control board via IO port.
3. The Infrared Transceiver Module is used to help me receive and record the infrared signals sent by the air conditioner remote control. It can also transmit the recorded infrared signals to the air conditioner via infrared emission. This enables my main control board to easily control the air conditioner.
Next
The complete step-by-step tutorial is here, and you could also discover more interesting projects :)
