The idea here lies on the idea that we haven't tapped yet into the full potential of the raspberry pi in terms of ADC.
Some have shown that the first gen of Raspberry could go to 10Msps as detailed here https://digibird1.wordpress.com/raspberry-pi-as-an-oscilloscope-10-msps/
My take is that the new Raspberry Pi.es (3 or even W) can surely go above. And I want to try it, either with this old CA3306E or with more recent kick-ass ADCs.
Let's see!
kelu124
See the full log at
For general info, here's what the GPIO memory looks like during 10k samples at 10MHz =)
and here's what 2 ADCs normally interleaved produce when one the ADCs has two output pins soldered together:
At least I still have one ADC to play with, and experiment!
Not bad! The oscilloscope gives the same results:
So I'm quite happy with it! Again see the full notebook at
Hi @kelu124, for a sensor application I am testing, I would need a AD converter with a sampling rate of 20Msps connected to a RTU for doing live data processing. I know that RasberryPi cannot achieve that; have you developed your project further, do you know systems which can achieve that (without going to NI products), or would you be interested in cooperate to build one?
