20Msps+ ADC RaspberryPi HAT
Always wanted to have Msps ADCs on a Raspberry ... Let's dig into it.
Who doesn't need a quick and dirty ADC pHAT for her/his pi, especially these small wireless marvels? I know I need one, for trigger-based, burst action.This project aims at testing the capabilities of the piW in terms of managing external ADCs - will start from the well-documented CA3306E, move forward to the 8-bit ADC08200, and why not move higher and faster as it goes?I've always needed a small upgrade to the existing raspberry ADC extensions, would love something in the 20-Msps range. Let's see if one can do it ! Never tried smd, and thinking of using both smd and dip.. interesting learning curve ahead.The first application I can think of is to support the acquisition for my ultrasound imaging project ( at https://hackaday.io/project/9281-murgen ), where I need to sample a +- 3.3V signal coming from the analog processing board. Would be keen to see h
The idea here lies on the idea that we haven't tapped yet into the full potential of the raspberry pi in terms of ADC.
Some have shown that the first gen of Raspberry could go to 10Msps as detailed here https://digibird1.wordpress.com/raspberry-pi-as-an-oscilloscope-10-msps/
My take is that the new Raspberry Pi.es (3 or even W) can surely go above. And I want to try it, either with this old CA3306E or with more recent kick-ass ADCs.
Let's see!
View all 10 project logs
acarretti wrote 05/04/2020 at 21:44 point
Hi @kelu124, for a sensor application I am testing, I would need a AD converter with a sampling rate of 20Msps connected to a RTU for doing live data processing. I know that RasberryPi cannot achieve that; have you developed your project further, do you know systems which can achieve that (without going to NI products), or would you be interested in cooperate to build one?
Tindie wrote 06/23/2017 at 00:23 point
Congratulations on being one of the Internet of Useful Things Hackaday Prize Finalists!
Gintaras Valatka wrote 06/19/2017 at 19:29 point
Love the ultrasound imaging project, maybe this could also give you some interesting ideas on ADC  https://hackaday.io/project/9877-analog2pi
kelu124 wrote 06/19/2017 at 20:01 point
Thanks for the heads up, interesting device !
Damon wrote 05/01/2017 at 04:15 point
could this be used to create crazy oversampled oscillators for audio/music/synth purposes?
kelu124 wrote 05/01/2017 at 07:51 point
Hey @Damon the ADC would need to be replaced by a DAC, but I assume indeed you'd be able to synthethise signals up to 10Msps =)
Damon wrote 05/01/2017 at 12:08 point
lol right
