First publication of the layered-light interpretation hypothesis
A project log for Layered-light interpretation of galactic rotation
This project proposes an optical–structural hypothesis for the flat rotation curves of spiral galaxies. Instead of invoking invisible mass,
younes-hassanabadiYounes HASSANABADI 11/25/2025 at 15:360 Comments
This log marks the first public release of my **layered-light interpretation hypothesis** for galactic rotation curves.
In standard cosmology, flat rotation curves are usually interpreted as strong evidence for dark matter. In this project, I explore a different angle: the idea that part of the “anomaly” might come from the way light is blended and scattered inside a spiral galaxy, before it reaches our telescopes.
The core idea is simple to state:
> The light recorded at the visible edge of a galaxy is not purely the light of local outer stars, but a mixture of several structural layers.
> If bright, fast inner layers contribute enough scattered light along the same line of sight, their Doppler signature can contaminate the outer spectra and artificially increase the *apparent* rotation speed at large radii.
In the **Details** section I present the full argument:
– how rotation curves are usually measured,
– why multilayer structure and beam smearing matter,
– the role of dust and H I gas in building diffuse galactic light,
– and a simple symbolic formulation for the effect on the inferred velocity.
### Language versions
The full text of the hypothesis is available in three languages:
- **English** – main version, in the *Details* section and as a `.docx` file
- **French (français)** – see the `.docx` file under the *Files* tab
- **Persian (فارسی)** – also available as a `.docx` file under *Files*
Feedback is very welcome — especially on:
- physical assumptions that might be missing or oversimplified,
- possible observational tests or simulations that could confirm or falsify this idea,
- related work I may have missed in the literature.
Thanks for reading, and feel free to comment or fork the idea if you want to push it further.
