# First feedback: H I / radio observations and next steps
This log records the first serious feedback I received on the **Layered-Light Interpretation (LLI)** hypothesis, and how it affects the scope of the idea.
Shortly after publishing the project, [Namik Yer](https://hackaday.io/hacker/17351-namik-yer) raised a very important point:
> What about radio / H I observations?
> Many galaxy rotation curves are derived from the 21 cm line of neutral hydrogen, not only from optical starlight.
> In the outer H I regions there is very little dust, and radio waves are not affected by scattering in the same way as visible light.
This is a **critical challenge** for any explanation that is purely optical.
## 1. What I currently think about H I and LLI
At the moment, my view is:
- In the **dusty, optically bright inner and intermediate disk**, the LLI mechanism (mixing of inner and outer light along the line of sight) could bias the inferred velocities.
- In the **outer H I regions**, where dust is minimal and the 21 cm line is used, the observed flatness is much more likely to be genuinely dynamical (and there dark matter or modified gravity may still be needed).
So LLI is **not** intended as a complete replacement for dark matter in the radio / H I regime.
It is better understood as an **optical / structural correction** for the stellar, dusty part of the rotation curve:
- shrinking or reshaping part of the anomaly,
- rather than eliminating the need for extra gravity everywhere.
A serious test in the future would be to compare **optical** and **H I** rotation curves for the same galaxies and see in which radial ranges they diverge or agree.
## 2. Towards a “toy model” (first quantitative step)
The feedback also makes it clear that LLI must eventually move from a purely conceptual framework to at least a **simple quantitative model**.
My first goal is to build a *toy model*:
- Use a simplified, two-layer galaxy:
- inner, bright, fast layer with speed `v_in`
- outer, faint, slower layer with true speed `v_out_real(r) ∝ 1 / sqrt(r)`
- Assign light intensities:
- `I_out(r)` decreasing with radius (outer stars)
- `I_in->out(r)` representing a small “leakage” of inner light into the outer line of sight
- Compute the apparent velocity:
- `v_eff(r) = (I_out * v_out_real + I_in->out * v_in) / (I_out + I_in->out)`
By plotting both `v_out_real(r)` and `v_eff(r)` for different choices of `I_in->out / I_out`, I can check:
- how strong the inner-light contamination must be to noticeably flatten the apparent rotation curve,
- and whether this effect is potentially significant or only a tiny correction.
Even such a simple model (implemented in Python or even in a spreadsheet) would already help clarify how “strong” LLI would have to be in order to matter.
## 3. Next steps
From this first feedback, my updated roadmap is:
1. **Clarify the scope** of LLI in the write-up:
- explicitly separate the dusty, optical inner disk from the outer H I regime;
- state clearly that LLI is a methodological / optical correction, not a full substitute for dark matter.
2. **Build a first toy model**:
- two or three layers (bulge + disk),
- simple intensity and velocity profiles,
- compute and plot `v_eff(r)` vs `v_out_real(r)`.
3. Later, if possible:
- compare optical vs H I rotation curves in the same galaxies,
- and explore whether LLI can plausibly contribute to part of the observed flatness in the inner / intermediate regions.
Many thanks again to Namik for raising the H I / radio question and for pointing in the direction of quantitative tests. This is exactly the kind of critical input that helps transform the hypothesis into something that can be checked, constrained, or even falsified.
Younes HASSANABADI
