OSUG: Open-Source Underwater Glider
A versatile autonomous environmental drone using a buoyancy engine
There has been a breakthrough with low cost autonomous drones and as this capability has matured a wide range of hobby and commercial applications have developed. There are no affordable extended duration underwater exploration platforms and this project aims to address this need.
Utilising commodity hardware, 3D printed parts and an open-source autopilot, I aim to produce a low cost and versatile underwater glider capable of extended missions of up to weeks at a time. I hope that by having this platform available, it would reduce the cost of underwater projects for all, from hobbyists, amateur scientists to seafood farmers.
Contents
Interesting logs
The CAD model
The model is viewable on the Onshape online platform here (requires webGL)
Video
Why a glider?
Traditional unmanned underwater vehicles depend upon active propulsion, limiting their range and runtime, making them unsuitable for long duration monitoring missions. Underwater gliders use a buoyancy engine to change the mass of the glider, allowing them to ascend and descend through the water. With power only being used to power the engine intermittently, gliders can typically run for weeks or months without recharge, making them ideal for environmental monitoring. Yet there are few commercial solutions available (and those that are available are very expensive) and even fewer hobbyist projects exist.
As underwater gliders travel slowly through the water, they disturb the surrounding water very little, allowing for accurate and reliable data recording. Underwater gliders are normally AUVs (Autonomous Underwater Vehicles) and can run a pre-determined route without requiring human interaction. Their low speeds and autonomy, combined with long battery life, make underwater gliders ideal for long duration, environmental monitoring missions, capable of recording dissolved gas levels, pH, temperature and optical sensing (for oceanic surveying and sealife recording).
This glider is open-source, with 3D printed components combined with readily available hardware, allowing it to be assembled for a low cost. Given the openness of the project, the project could be forked to produce alternative designs suited to particular scenarios. For instance; changing the tubing to aluminium to become a deep sea glider or using a unique sensor array for specialised applications.
I am looking to use the open-source Mission Planner combined with the Pixhawk autopilot platform, allowing the glider to be controlled using a standardised interface.
Example use case
With increasing interest in product transparency and traceability, environmental monitoring is becoming increasingly important; a kelp farmer could use the glider to monitor water conditions (temperature/pH/nutrition levels/pollution) during a season of growth and push the measurements to a blockchain. The kelp/seafood could be packaged with a QR code, which would direct you to a web frontend, presenting the conditions during the season of growth. The use of the blockchain and data insurance for measurement storage would remove the chance of measurement tampering, so the consumer would know both the conditions that their food grew in and exactly what they’re eating.
Above: A block diagram outlining the how the glider could be used for product traceability
How?
For the glider to move, the buoyancy engine takes in water and increases the density of the glider. When the density of the glider becomes greater than that of the surrounding water, the glider descends. The wings of the glider ensure that the glider goes forwards and the angle of attack can be altered to cause different glider characteristics. When at the bottom of the descent, the buoyancy engine will expel the contained water, making the glider more buoyant, causing it to ascend, moving forward again.
The buoyancy engine that I have designed uses an acme rod to move the ends of the syringes when rotated by a stepper motor, causing the plungers to take in water. When water is taken in, the volume of the glider remains constant, but the overall mass increases, therefore the overall density of the glider increases and the glider becomes less buoyant.At the centre of the glider will be...
GNU GENERAL PUBLIC LICENSE V3.pdf
This project uses the GPL v3 license​ for all software related to the glider.
Adobe Portable Document Format - 78.20 kB - 10/21/2017 at 10:31
Preview
Download
demo.ino
Arduino demo program for gliding forwards by descending and ascending
ino - 2.79 kB - 10/14/2017 at 23:02
Download
Calibration.ino
Arduino calibration program for calibrating the buoyancy trim of the glider
ino - 2.51 kB - 10/14/2017 at 23:02
Download
End_caps.pdf
Endcap drilling guide
Adobe Portable Document Format - 5.63 kB - 10/10/2017 at 22:58
Preview
Download
scad - 8.97 kB - 10/14/2017 at 22:30
Download
View all 54 files
  • 1 × Printed parts
  • 1 × Blue Robotics 4" tubing 1000mm The main tubing
  • 1 × MPU6050 Gyroscope/accelerometer
  • 3 × A4988 Stepper motor driver Stepper motor drivers
  • 6 × 18650 Protected cells Litium-ion batteries
View all 73 components
  • Pogo pin board replacement
    alexw03/07/2018 at 19:56 0 comments
    The glider has 2 physical sections internally, the first is the buoyancy engine section and the second is the control boards and the pitch mechanism. The current design (below) uses pogo pins and a pair of boards to electrically connect the two sections, however this has two main downsides.
    The first problem with the pogo pins is that they use a spring mechanism in order to ensure a reliable connection, this causes the two sections of the glider to be pushed apart when the glider is assembled, which reduces the reliability of the connection. The other issue with this connection type is that the travel of the pogo connectors is only a few mm, which means that the rest of the glider must be aligned to within a couple of mm - the current solution to this is the sliding mounting bracket of the pogo connector PCB.
    With this in mind, the ideal connection would be one that does not have a spring contact and has ~10mm of travel. After having a look I was able to find the PCB contacts from Harwin that do exactly that, namely the H3169 and H2170 connectors.
    I ordered some sample connectors and they came through and were a perfect match for what I wanted, so I went ahead and purchased ~20 more connectors and designed some boards in Eagle for the two sides of the connector. Below is an image showing that the connectors in varying positions, all with solid electrical connections.
    I designed some updated boards for the ordered the PCBs through OSHpark and a massive shoutout to Drew (@pdp7) for providing great customer service and making sure I got my boards within a week. Below are some images of the boards and what they look like with the PCB connectors attached.
    This new configuration also more equally distributes the force of the contacts through the plate, as opposed to on the small section at the top. I designed and printed an updated PCB mounting bracket and you can see how the board fits in-between the alignment rods:
    Although using Onshape was an interesting experience, I am now transitioning to Solidworks for the design of the glider, but understanding that not everyone has access to Solidworks, I will still be providing the STL files so anyone can download and print the parts. The PCB files are also in the Dropbox development folder.
  • Assembled control board and backend update
    alexw01/26/2018 at 06:16 0 comments
    The backend has been redesigned to be much more open for the new control board, and all the connectors are much more accessible. Also the control board has been lowered to allow for the integration of the Pixhawk 2.1 autopilot (the Cube took up too much vertical space previously). Most of the update to V3.1 has been completed but wiring still has to be completed.
    The planetary gearbox has also been thickened to reduce play, but the latest version printed with too much of a bond between gears so I plan on reprinting this on a FORM 2 printer as this will be able to achieve a much better tolerance. I also changed the position of wiring past the planetary gearbox; previously the wiring ran on the side of the gearbox, which limited rotation, however the wiring now passes over the top of the gearbox and rotatory limits are symmetrical.
    Nothing noteworthy has occurred to the mass assembly, apart from the general thickening of printed pieces.
    The exterior components have been reprinted in 100% PLA and are not resin coated (The prints previously failed with 100% infill and let in water so had to be coated). However PLA still absorbed water – reports are a ~5% weight increase over a period of 30 days submerged, so I will look at printing the exterior components from PET-G.
  • Buoyancy engine update
    alexw01/26/2018 at 06:07 0 comments
    The last few weeks have been completely hectic and I have been unable to find time to document progress. I’m currently on a flight from London to Los Angeles to take up a residency at Supplygrame’s DesignLab to work on the glider, so I thought it would be a good time to do a few updates on the glider’s progress. I’ll split the update into two shorter sections, one for the buoyancy engine and another for the backend.
    Throughout most of the upgrade from version 3 to 3.1 I have been thickening components to improve structural strength, notably in the buoyancy engine. Below are two images of the engine, before and after the upgrade.
    Also note that the stepper motor has been upgraded from a NEMA 17 to a NEMA 23 motor, which runs at an equal power but has far greater torque. I have also moved the buoyancy engine stepper motor driver from the control board to mounted at the front of the glider, so that communication wires can be of a lower gauge and greater power can be delivered to the engine’s stepper motor. I have also upgraded the stepper motor from a A4988 to an AMIS-30543, as stated in my previous update. This allows for SPI communication to control the stepper motor more accurately and alter coil current on the fly.
    All of the glider’s components in contact with water are rated to a depth of at least 100m, apart from the buoyancy engine. Therefore a depth rating of the glider can be determined by pressure testing the buoyancy engine (unless it can perform to a depth greater than 100m, which is almost guaranteed to be false). Hence I meant to test the buoyancy engine, however I was time constrained and air is a harder medium to deal with than I initially thought. Regardless, I’ll outline briefly the attempted testing method for anyone is interested.
    The idea was to connect the engine to a water barrel using the same tubing and connectors that are within the glider, to try and accurately represent the system used. The barrel then had a pump attached (it was a car tyre pump until a lack of suitable power source became an issue) to pressurise the water within the container until the engine failed. The engine would constantly pump as I believed the syringe seals were more likely to fail when moving. Unfortunately the seal at the top of the container wasn’t sufficient and even after multiple layers of airtight tape there were small leaks that would reduce pressure within the container. I was going to switch to using a silicone sealant to properly air-tighten the container but I ran out of time.
  • Control board v0.3 designed and ordered
    alexw01/10/2018 at 19:34 0 comments
    Over the last few days I've updated the design for the control board, with two notable improvements. The first is the hook-up of the "enable" pins of the stepper motor drivers to the ATMEGA2560, so that it is possible to power down the drivers whilst not in use in order to maximise battery life. The other main update is the removal of the A4988 for the buoyancy engine stepper motor, instead sending signals to an AMIS-30543 stepper motor driver board, which is mounted at the front of the glider next to the buoyancy engine. The AMIS-30543 has a greater current capability (3A vs 1.8A) and uses the SPI communication to control current, sleep, etc. I made sure that the new PCB could fit lower down in the 4" enclosure, in order to accommodate a full Pixhawk 2.1 (the vertical height of the "Cube" meant that it previously wouldn't fit).
    The PCBs are being manufactured by OSHpark and I should have some assembled boards by mid next week. As usual, all design files are in the development DropBox folder, in the Underwater_glider/glider_pcbs/Control_board/v0.3 directory.
    Over the coming days I will be testing the buoyancy engine to potentially determine a working depth limit.
  • General update
    alexw12/02/2017 at 18:28 0 comments
    The last few weeks have been completely hectic with the Hackaday prize and sorting out university, things are only just starting to settle. It was really great to go over to the US for the Supercon, I enjoyed meeting everyone and I appreciate all the useful feedback I recieved. As part of winning the Hackaday prize, I hope to take up the residency at Supplyframe's DesignLab in the New Year and this will give me a three month period to focus solely on the glider.
    Over the coming weeks I'll be updating the design of the glider from v3 to v3.1, a version of the glider that I believe will be suitable for alpha kits for real world testing. During the glider update I will be testing various parts of the glider to ensure reliability and to get some performance figures.
    The main testing will be on the buoyancy engine, so I have a depth rating and an understanding as to how well it performs. As the glider/buoyancy engine is quite large it will be hopefully be done in a modified water tank with a car pump attached. A camera on the inside of the tank will be used to monitor the state of the buoyancy engine to make sure there are no leaks, etc.
    For those interested in kits, I appreciate the support and I am aiming at finalising the design so that I can come up with a finalised cost. I looked at printing the parts using 3D printing services but it is more effective print the parts myself, so I have purchased a CR-10 printer for printing sets of parts.
    You can view the live development CAD of v3.1 here. Red is v3 parts and the blue parts are parts that have been updated to v3.1
  • Future testing and to-do list
    alexw10/18/2017 at 17:18 0 comments
    As the third generation of hardware is completed for the glider, it has reached a stage where it needs to undergo testing to find the capabilities of the glider. Below are a few tests that need to be performed on the glider and a brief explanation of each test:
    • Testing of the buoyancy engine system to determine a depth rating of the glider - All of the exterior components of the glider (end-caps, switches, underwater plug etc) are rated to at least a 100m depth, whereas the buoyancy engine does not currently have a rating. A pressure test of the buoyancy engine (likely destructive) will determine the overall depth rating of the glider. (The test would be to attach all the syringes to another set of syringes with a plate on top, weight would be added to the plate until the stepper motor cannot move the weight or the seals break, if the former, the stepper motor will be upgraded.)
    • Perform reliability testing of the buoyancy engine under pressure to make sure that the movement systems do not become stiff. Minimum of 24 hours.
    • Perform underwater tests with the glider running at different glide angles, used to determine the best angle of attack for different missions (steeper = faster, shallower = greater endurance)
    • Perform extended endurance/range testing as the current endurance/range of the glider is calculated by extrapolating out current data (42 hour running battery life at ~0.2m/s = 28km). Once a depth rating of the glider is achieved, the glider can glide to a greater depth which will mean that it reaches a greater speed and spends less of its time transitioning between gliding states, so the range of the glider will increase.
    • As I have only been able to test the glider in small areas of water, it has not been possible as of yet to demonstrate the turning of the glider clearly, so the glider needs to be tested in a larger body of water.
    I have also put together a to-do list to get the glider to version 3.1. This list is primarily hardware and does not include any to-do points concerning the Pixhawk and automated waypoint navigation system. An up-to-date version of this to-do list will be kept in the dropbox folder.
    Printed components
    • Change acme nut to an anti-backlash nut to prevent acme screw wear in the long term
    • Redesign wing mounts to have a slight dihedral so that the glider is more stable underwater
    • Choose a standardised micro lever switch and use screws as opposed to hot glue
    • Make the planetary gearbox thicker to reduce play/wear
    • Redesign the wiring routes past the planetary gearbox
    • Redesign the Pixhawk mounting plate so that the board can be more easily placed/removed
    • Try and fit all of the external ballast bars internally, to reduce drag etc
    • Change all roll components to a diameter of 98mm, as opposed to 100mm (to reduce friction inside the tubing)
    • Strengthen endcap mounts to prevent bowing
    • Strengthen engine bearing fastener to prevent bowing
    • Redesign motor/acme clamps to increase strength
    • Upgrade buoyancy engine motor to a NEMA 23 motor if required
    • Make pogo PCB mounting plates thicker to prevent bowing
    PCB
    • Hookup the “enable” pins of the A4988 boards, so that you can power off the stepper motors when they’re not in use to increase battery life
    • Hookup a greater number of the unused I/O pins to header pins to increase the number of additional sensors, etc. that can be used
    • Reposition the A4988 stepper motor drivers so that you can access all of the potentiometers without drilling into the aluminium tubing
    • Use the Blue Robotics switch as switch to a relay for the main power control - the switch is potentially getting to the edge of its current capability
    General
    • Think of an alternative to aluminium tubing, to reduce variability in reproduction
    • Upgrade the hotend of the printer and print all components in polycarbonate
    • Apply for Sparkfun funding for their dissolved oxygen sensor
    • Contact Onshape on their forums with review/feedback - global parameters or feature folders are the main suggestions...
  • Build instructions and possible kits
    alexw10/15/2017 at 09:27 11 comments
    Full instructions for the glider are now completed, with a level of detail that if you're able to assemble a RepRap kit, you should be able to assemble the glider. The only tools required are a 3D printer, soldering station, dremel and then various handtools such as hacksaw/allen keys etc.
    With the Onshape CAD model, you are able to duplicate the model and adapt the hardware for your own requirements (such as adding a front mounted camera) - this glider is designed to be a hardware platform for others to use/adapt, not a project with a fixed use case.
    If there is interest, I may look into the possibility of putting together a few kits containing all parts/3D printed components that are known to work together so you can assemble the whole glider in a couple of weekends.
  • Assembled CAD model (and onshape features)
    alexw10/10/2017 at 10:45 0 comments
    I've finished assembling the Onshape CAD model for the third generation of the glider. It can be viewed here. There are a couple of features of Onshape that make visulisation of the model/sub-systems easier. You can hide objects which completely removes them from view (Useful for the tubing as it then allows you to select internal components). You can also isolate a component (or multiple) which makes all other components faded and makes it very clear as to what the individual components look like etc.
  • Final(ish) third generation hardware
    alexw10/07/2017 at 16:13 0 comments
    I have gone over the glider CAD model and I have changed the parts so that no post processing is required (unless I've missed something).
    Within the Onshape model, the test prints should be printed first and they are used to select values for the component variables.
    I am aware there is currently a lack of instructions for the third generation of hardware but all the images of the assembly can be found in the dropbox folder.
    I should update the project page soon with full instructions for the assembly of the glider.
  • Ascending and descending underwater
    alexw09/22/2017 at 21:54 0 comments
    Just a quick update regarding some testing of the new hardware: I recently had access to a pool and I was able to test the glider's new hardware in deeper water. There is currently no control software onboard, so the glider is dead reckoning using set timer delays (4 seconds down, 4 seconds up). The pitch mass is not varied during the duration of the filming. The angle of attack is currently quite steep, but this will be optimised as a PID algorithm becomes integrated. The tether at the back of the glider is only there for remote programming, which made it quicker to modify timings whilst the glider was in the water; the tether did not need to be attached whilst it was performing this gliding sequence.
View all 32 project logs
  • 1
    Build notes
    • Given vibrations throughout the glider due to the stepper motors, I would recommend using threadlock or locknuts throughout the build.
    • Most of the parts are parameterisable and should be adjusted to your printer. However, there will be parts of the prints that require a small amount of sanding/drilling to make sure that holes are the correct size.
    • If there are any errors with the build instructions or CAD components (or if you have any CAD part name suggestions - I lost imagination after a while), leave a message and it shall be fixed as quickly as possible. All suggestions are very welcome.
    • On the Hackaday page are a set of STL files with custom values for my particular printer. While these may work for your printer, it is suggested to print the files with custom part variables for your printer, determined by printing a set of test pieces as outlined further on in the instructions.
    • As the Hackaday’s project editor is slow to work with, I made all of the instructions on a google docs documents. When I ported the instructions across all the images became slightly out of proportion and there are too many images to manually change them all. You can view the images in the correct proportions if you click on the image. You can also view all of the images on the Dropbox image link
  • 2
    Preparation of PCBs
    Some board services leave tabs on the PCBs, so you can remove these and sand the edges of the board smooth.
  • 3
    Soldering SMD components
    This step uses hotplate surface mount soldering, a more detailed example of this technique, including video, can be found here at hobbytronics.
    Using a non-food hotplate, heat the PCB slightly, this allows the solder paste to be applied more thinly as it is less viscous and comes out of the syringe more easily.
    Apply the solder paste to the SMD pads, as shown highlighted in red. Use the tip of the solder paste extruder/cotton buds/kitchen towel to remove excess solder paste from the pads. Surface tension will cause the solder to go onto the pads on the atmel chip, so don't worry about connecting them all at this stage.
    Using tweezers, place the SMD components onto the board. R1/R2/R3/R4 are 10K‎Ω resistors and C1/C2 are the 22pF capacitors. Only the atmel chip is orientation specific, so make sure that the alignment dot on the chip lines up with the star on the board. Make sure that the atmel chip's pins line up with the pads on the board.
    In order to form the solder joints, heat the hotplate up to its maximum setting and watch the pads closely. When the solder paste gets near the required temperature, it will turn into a liquid, and it will then gain the silver solder appearance as it continues. Make sure that all of the solder joints have been formed before removing the board from the heat.
    Some of the pins of the atmel chip will have bridged, so use desolder braid to remove the excess solder causing bridging. Use a multimeter continuity tester to check that no pins are connected to the pin next to them.
View all 25 instructions
Legrange wrote 04/10/2017 at 10:16 point
This is cool, I have an affinity for things that go under water.
Curious as to how precise your syringe control is and how precise do you need it to be to function properly? Have you done any real life experiments on the control system, if not, how soon before you try things out? How long before you have a workable prototype of the whole thing?
alexw wrote 04/12/2017 at 10:26 point
I have finished printing about half of the components, and the other half should be quicker to print (I printed the larger components first). I will then be able to assemble the glider and see if anything stands out as being incorrect. Following that, I will design the control circuits and control software.
The capacity of the syringes (180ml) compared to the volume of the glider (~6000ml) is 0.03, whereas the Slocum glider's volume change (450cc) compared to volume (52000cc) is 0.009. From these figures, it seems that the change in density will be sufficient. That being said, I am still sceptical of my glider, as the Slocum glider is clearly much larger and I am unsure as to what degree that will affect the required volume change.
The threaded bolt used to drive the syringes allows for a very precise control over the volume of water taken in; hooking up a stepper motor to the syringes makes it look like repeatable volume change of 0.1cc is possible.
I am currently in the lead up to exams, so will be able to put minimal time into the project over the next 2/3 months. However, following that, I have about 3 months free in which I will do a large amount of development and I hope to come to the point where I am able to perform real life tests on the control systems (simple ascending/descending and pitch control).
Legrange wrote 04/12/2017 at 19:35 point
Thanks for your reply. It's good you're keeping grounded and sceptical. I look forward to hearing more about this project as you get the time to work on it.
Peter McCloud wrote 04/04/2017 at 04:06 point
Great looking CAD model
alexw wrote 04/04/2017 at 09:25 point
Thank you. Functionally, the model has a way to go, but it's more or less there visually
