GNU GENERAL PUBLIC LICENSE V3.pdf
This project uses the GPL v3 license for all software related to the glider.
Adobe Portable Document Format -
78.20 kB -
10/21/2017 at 10:31
Preview
demo.ino
Arduino demo program for gliding forwards by descending and ascending
ino -
2.79 kB -
10/14/2017 at 23:02
Download
Calibration.ino
Arduino calibration program for calibrating the buoyancy trim of the glider
ino -
2.51 kB -
10/14/2017 at 23:02
Download
End_caps.pdf
Endcap drilling guide
5.63 kB -
10/10/2017 at 22:58
Preview
Planetary_gearbox.scad
scad -
8.97 kB -
10/14/2017 at 22:30
Download
Control_board_v0.2.1_Gerber_RS274X.zip
Zip folder containing gerber RS274X files for the control board PCB (generated using OSHpark's "OSHPark 2layer <a target="_blank" rel="noopener noreferrer" href="http://Eagle7.2.cam">Eagle7.2.cam</a>" cam job)
x-zip-compressed -
147.84 kB -
10/15/2017 at 08:40
Download
Buoyancy_engine_connector_female_Gerber_RS274X.zip
Zip folder containing gerber RS274X files for the female pogo connector PCB (generated using OSHpark's "OSHPark 2layer <a target="_blank" rel="noopener noreferrer" href="http://Eagle7.2.cam">Eagle7.2.cam</a>" cam job)
x-zip-compressed -
10.68 kB -
10/15/2017 at 08:42
Download
Buoyancy_engine_connector_male_Gerber_RS274X.zip
Zip folder containing gerber RS274X files for the male pogo connector PCB (generated using OSHpark's "OSHPark 2layer <a target="_blank" rel="noopener noreferrer" href="http://Eagle7.2.cam">Eagle7.2.cam</a>" cam job)
x-zip-compressed -
11.54 kB -
10/15/2017 at 08:45
Download
Control_board_v0.2.1_Gerber_RS274X_eagle.zip
Zip folder containing gerber RS274X files for the control board PCB (generated using Eagle's "gerb274x" cam job)
x-zip-compressed -
143.67 kB -
10/15/2017 at 09:54
Download
Buoyancy_engine_connector_female_Gerber_RS274X_eagle.zip
Zip folder containing gerber RS274X files for the female pogo connector PCB (generated using Eagle's "gerb274x" cam job)
x-zip-compressed -
9.05 kB -
10/15/2017 at 09:53
Download
Buoyancy_engine_connector_male_Gerber_RS274X_eagle.zip
Zip folder containing gerber RS274X files for the male pogo connector PCB (generated using Eagle's "gerb274x" cam job)
x-zip-compressed -
10.02 kB -
10/15/2017 at 09:49
Download
Control_board_v0.2.1_drill_files.zip
Drill files for the control board PCB generated using Eagle's "Excellon" cam job. There are two files "DRI" (Drill Station Info File) and "DRD" (NC Drill File).
x-zip-compressed -
1.38 kB -
10/15/2017 at 09:59
Download
Buoyancy_engine_connector_female_drill_files.zip
Drill files for the female pogo connector PCB generated using Eagle's "Excellon" cam job. There are two files "DRI" (Drill Station Info File) and "DRD" (NC Drill File).
x-zip-compressed -
842.00 bytes -
10/15/2017 at 10:01
Download
Buoyancy_engine_connector_male_drill_files.zip
Drill files for the male pogo connector PCB generated using Eagle's "Excellon" cam job. There are two files "DRI" (Drill Station Info File) and "DRD" (NC Drill File).
x-zip-compressed -
856.00 bytes -
10/15/2017 at 10:08
Download
Control_board_v0.2.1.brd
brd -
257.94 kB -
10/14/2017 at 22:31
Download
Buoyancy_engine_connector_female.brd
brd -
24.67 kB -
10/14/2017 at 22:30
Download
Buoyancy_engine_connector_male.brd
brd -
23.04 kB -
10/14/2017 at 22:30
Download
Control_board_v0.2.1.sch
sch -
568.98 kB -
10/14/2017 at 22:31
Download
Buoyancy_engine_connector_female.sch
sch -
28.09 kB -
10/14/2017 at 22:30
Download
Buoyancy_engine_connector_male.sch
sch -
24.03 kB -
10/14/2017 at 22:30
Download
Planetary_gearbox.stl
Standard Tesselated Geometry -
2.55 MB -
10/14/2017 at 22:31
Download
Printed_parts - Tail_endcap_shroud.stl
3.73 MB -
10/14/2017 at 22:31
Download
Printed_parts - Wing_mount.stl
Print 2
981.33 kB -
10/14/2017 at 22:31
Download
Printed_parts - Pogo_header_slider_mount.stl
2.99 MB -
10/14/2017 at 22:31
Download
Printed_parts - Nosecone.stl
7.17 MB -
10/14/2017 at 22:31
Download
Printed_parts - Syringe_plunger_back.stl
838.56 kB -
10/14/2017 at 22:30
Download
Printed_parts - Syringe_plunger_front.stl
574.50 kB -
10/14/2017 at 22:30
Download
Printed_parts - Syringe_clamp_front.stl
904.38 kB -
10/14/2017 at 22:29
Download
Printed_parts - Syringe_clamp_back.stl
904.77 kB -
10/14/2017 at 22:29
Download
Printed_parts - Engine_endstop.stl
67.66 kB -
10/14/2017 at 22:29
Download
Printed_parts - Buoyancy_engine_motor_mount.stl
2.44 MB -
10/14/2017 at 22:29
Download
Printed_parts - Pogo_header_front_mount.stl
1.45 MB -
10/14/2017 at 22:29
Download
Printed_parts - Roll_motor_mount.stl
889.24 kB -
10/14/2017 at 22:29
Download
Printed_parts - Engine_end_connector.stl
1.15 MB -
10/14/2017 at 22:29
Download
Printed_parts - Fathom-S_mounting_bracket.stl
446.27 kB -
10/14/2017 at 22:28
Download
Printed_parts - Exterior_bar_mount.stl
306.33 kB -
10/14/2017 at 22:28
Download
Printed_parts - Engine_endcap_mount.stl
598.91 kB -
10/14/2017 at 22:28
Download
Printed_parts - Pitch_motor_mount.stl
1.87 MB -
10/14/2017 at 22:28
Download
Printed_parts - Circuit_rack_endcap_mount.stl
977.04 kB -
10/14/2017 at 22:28
Download
Printed_parts - Engine_bearing_fastener.stl
Print 2
185.24 kB -
10/14/2017 at 22:28
Download
Printed_parts - Battery_mount_acme.stl
1.15 MB -
10/14/2017 at 22:27
Download
Printed_parts - Pixhawk_mounting_plate.stl
132.99 kB -
10/14/2017 at 22:27
Download
Printed_parts - Circuit_rack_end.stl
541.68 kB -
10/14/2017 at 22:27
Download
Printed_parts - Pogo_header_back_mount.stl
166.49 kB -
10/14/2017 at 22:27
Download
Printed_parts - Buoyancy_engine_bearing_plate.stl
1.13 MB -
10/14/2017 at 22:26
Download
Printed_parts - Cable_chain_nut_holder.stl
59.65 kB -
10/14/2017 at 22:26
Download
Printed_parts - Pitch_motor_back_plate.stl
797.15 kB -
10/14/2017 at 22:26
Download
Printed_parts - Acme_motor_connector.stl
782.41 kB -
10/14/2017 at 22:26
Download
Printed_parts - Battery_rods_cover.stl
292.07 kB -
10/14/2017 at 22:26
Download
Printed_parts - Battery_mount_bearings.stl
1.25 MB -
10/14/2017 at 22:26
Download
Printed_parts - GPS_mounting_plate.stl
95.20 kB -
10/14/2017 at 22:26
Download
Printed_parts - Battery_mount_connector.stl
199.69 kB -
10/14/2017 at 22:26
Download
Printed_parts - Acme_bearing_front.stl
272.35 kB -
10/14/2017 at 22:25
Download
Printed_parts - Acme_bearing_back.stl
205.55 kB -
10/14/2017 at 22:25
Download
