Good day to all,
A couple months ago, and back from much longer even, I had the idea to mutualize the application software and embedded software by using building blocks.
As the idea matured, early this year, i began porting old code from a PIC16 (PIC16F886) microcontroller to a project that connected it to the computer through a Web GUI running HTML/JS.
This worked quite well and ended up in a GUI Lab that showed the GPUI, allowed to toggle them, put them into different mode (input, output), and read-back the values.
From this point on and as the work included a clean exchange specification, it was possible and easy to extend the project so as to make it a platform for application design.
Just yesterdat, the 6 decembre 2025, i put my hands into developping the basic firmware for Arduino R4 Minima, and the resut was this project being released on Github including the Windows software and Arduino firmware INO file, in just a couple hours.
The application i built is a very simple Analog read so the Analog pins can be monitored from a computer.
That enables a lot of simple applications to be done, for example charts/curves, a multi channel DC-Voltmeter, and a Data logger that connects to instruments and records the values, with a simple Breadboard circuit including Voltage Resistor bridge to adjust to the MCU level and mentionned Software stack.
As the project grows on, many possibilities are offered for it, for example, real world applications can be developped fairly fast provided the MCU with firmware is available, which as of today only includes the PIC16F628 and Renesas MCU used in the Arduino R4 Minima.
Compiling the code for other Arduino boards, or porting the PIC16F to custom MCU is not a very difficult work and potentially allows one to build high level applications running in JS/HTML and uniformly running on any hardware platform that's supported without need to recompile anything, as the way this project & SDK is designed, makes it agnostic to the hardware platform, as the commands go through the computer software, a console executable that provides a local HTTP server for GUI to run on top of, and a bridge to a standard COM port with a target that supports the MSP exchange specification on the other side.
Regards,
Jean-François
jfsimon
Jerry Isdale
Louis H
Rohan Barnwal
Ekawahyu Susilo
