Wi-Fi GPS Tracker with Seeed Studio XIAO ESP32-S3 & Geofencing
Tracking the location of things doesn’t have to mean pricey cellular plans and complex hardware. In this project, we build a compact Wi-Fi GPS tracker using a Seeed Studio XIAO ESP32-S3 and a Neo-6M GPS module, all tied together with an easy cloud backend called GeoLinker. The result: real-time position reporting, geofence alerts, and SMS notifications — without a SIM card or GSM modem
🧠 What is it?
This tracker continuously reads GPS coordinates from the Neo-6M module and sends them over Wi-Fi to the GeoLinker cloud service. GeoLinker then plots the device on a map and logs historical tracks for analysis. A built-in geofencing feature lets you set a virtual boundary around a location — and receive an SMS alert when the device exits it.
🔑 Key Features
  • 🚫 No Cellular Service Needed – Uses Wi-Fi and REST APIs instead of SIM/GSM modules.
  • 📍 Real-Time Tracking – GPS coordinates pushed to the cloud at adjustable intervals.
  • 🛑 Geofencing & Alerts – SMS notifications when the tracker crosses a defined boundary.
  • 💾 Offline Buffering – Stores GPS data when Wi-Fi is unavailable and uploads on reconnect.
  • 🗺️ Interactive Mapping – View route history and live location in your browser.
🛠️ How It Works
  1. GPS Fix — The Neo-6M GPS gets satellite signals and computes lat/lon.
  2. ESP32 Processing — The XIAO ESP32-S3 reads the GPS data over UART.
  3. Wi-Fi Upload — Coordinates are sent via Wi-Fi to the GeoLinker API.
  4. Geofence Logic — The code checks distance from a reference point using the Haversine formula.
  5. SMS Alerts — When outside the boundary, an SMS is triggered via a cloud API.
  6. Offline Mode — If Wi-Fi drops, data gets buffered locally and uploaded later.
🔌 Hardware You’ll Need
  • Seeed Studio XIAO ESP32-S3 – main controller with Wi-Fi.
  • Neo-6M GPS Module – for GPS coordinate acquisition.
  • Breadboard & Wires – for prototyping.
  • External GPS Antenna – improves satellite reception.
🔧 Software Stack
  • Arduino IDE – build and flash firmware.
  • GeoLinker Library – handles cloud comms.
  • TinyGPSPlus – parses GPS data.
  • WiFiClientSecure – HTTPS connectivity.
🧠 Code & Cloud Setup
You’ll need a GeoLinker API key for uploads and SMS services. The ESP32 code manages GPS reads, handles geofence checks, and talks to GeoLinker. If your Wi-Fi goes offline, the tracker keeps data in a buffer and resyncs automatically once reconnected.
📈 Real-World Uses
  • Vehicle & fleet tracking
  • Asset and equipment monitoring
  • Pet and personal trackers
  • Child or elderly geofence alerts
    No GSM subscription means lower operating costs and simpler builds.
📌 Tips & Customisation
  • Adjust the update interval for battery or data efficiency.
  • Change the geofence radius to suit your use case.
  • Add multiple geofences or speed alerts for richer behaviour.
A compact GPS tracker using Seeed Studio XIAO ESP32-S3 enables real-time location tracking and geofencing alerts over Wi-Fi without the need for a cellular SIM.
