Kit Specifications
- Enclosure (Box + Lid) - 80 × 96 × 40 mm
- Microcontroller - NodeMCU V3 ESP8266 Wi-Fi Module - 2.4GHz only
- Relay Board 4ch
- Input:
- VCC: Positive supply voltage (5V)
- GND: Ground
- IN1–IN4: Relay control port
- Output:
- Connect a load: DC 30V/10A, AC 250V/10A
- Input:
- Dupont F-F cables (10cm) – (Mirocontroller - Relay Board)
- LED diode (5mm)
- Screws (M3)
- Operating Conditions:
- Humidity ≤ 90
- Temperature: 0°C to 40°C
- Mobile App: roVad Smart
Features
- 4 independent relay channels
- AP Mode (offline, local control)
- Wi-Fi Mode (remote control via MQTT)
- LED indicator for mode and status
- Relay timers for automated switching
- Two-way Interactive Communication
- Send commands via MQTT or the ROVAD Smart App on your phone.
- The NodeMCU microcontroller responds immediately with real-time status or data.
- You can request information such as:
- Current relay states
- Timer settings
- Exact device time
- This enables full interactive control and feedback, making the system more responsive and intuitive.
- Compatible with ROVAD Smart Android App for dashboard control
- Light and Dark Themes
- Suitable for hobbyists, makers, students, and developers
Safety Notice
- High-voltage AC (110–250V) can be switched. Take extreme caution.
- Always disconnect power before assembly, wiring changes, or maintenance.
- Manufacturer is not responsible for damages due to misuse or improper assembly.
- If you are not experienced with electrical wiring, seek assistance from a qualified technician.
Two-way communication via the app allows real-time interaction with the microprocessor. Users can monitor relay statuses, time, and timers at any moment. We welcome your suggestions for new commands.
Roadmap
This project is part of a growing DIY smart home initiative. Future plans include:
- Upgraded kits: 6ch, 8ch, 16ch versions
- Continued roVad Smart App development with interactive elements
- New commands and advanced automation
- Community feedback integration
License & Disclaimer
- DIY educational and development purposes only
- Manufacturer assumes no liability for misuse, damage, or injury
- Follow standard electrical safety practices
Rovad
Subhajit
Alexander Else
