I am hoping for assistance with this. I want to build an HVAC system that not only controls itself bit also can determine upcomimg weather and advise you accordingly. I also want it to check itself for errors amd advise the user of problems and such. Such as reading refrigerant levels and any other issue it may encounter.
Hvac systems are a necessity in life. Well, a comfortable one. Just about everyone with one has problems that are difficult to diagnose. What if you went on vacation and the weather changed drastically. Wouldnt be nice to know you can change your temps or diagnose issues the ayatem may have from anywhere. What if you could tell the exact problems or failures of the entire thing and know the fix needed without paying someone to tell you. Thats the plan with this idea and i need help with it. I would like to start a team of developers to assist me in this process and create a brand new HVAC system that will be benificial for all.
