Initial EVPR code working, PX4 driver completed
A project log for EVPR: Electric Variable Pitch Rotor
An electrically actuated variable pitch rotor with a wireless interface
peter-mccloudPeter McCloud 10/02/2017 at 05:030 Comments
The initial code for both the EVPR master and slave nodes is FINALLY ready. Additionally the PX4 driver which passes the servo settings to the EVPR master node is also complete. The servo values are correctly being passed from the flight controller tothe master node via UART and the values are being successfully passed from the master node to a slave node via UDP packets.
The code can be found in the repository at the following locations:
EVPR Master Node
https://github.com/mccloudaero/evpr/tree/master/electronics/firmware_evpr_master
EVPR Slave Node
https://github.com/mccloudaero/evpr/tree/master/electronics/firmware_evpr_slave
PX4 Driver
https://github.com/mccloudaero/evpr/tree/master/electronics/px4_uart_driver
Now the electronics will be attached to the vehicle and more testing of the code can be conducted. If the servo values with the engine off are successfully received, then the testing can proceed to turning the engine and checking out the code on the running vehicle.
