Hackaday.io Hackaday.io
Sign up Log in
I Built a Robot Just to Feed My Dog
I repurposed Marlin, closed-loop steppers, and a PS4 controller to build a CNC robot on rails that does one thing very well: feed my dog.
whippetintechwhippetintech
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
751
0
2
1
Team (1)
  • whippetintechwhippetintech
Join this project's team
  • A German-Engineered Robot Arm Just to Feed My Dog
hardware
ongoing project
ROBOT marlin Robotics engineering closed loop control CNC python Cad nema 17 harmonic drive Motion Control automation
Related lists
General
Projects to come back to
This project was created on 12/30/2025 and last updated a month ago.
Description
I built this robot for a very simple and slightly absurd reason: feeding my dog. The project is intentionally playful and exists as a technical exploration rather than a replacement for actually caring for an animal. My dog is, of course, still fed normally — the robot is simply an excuse to build something complex, precise, and unnecessary. The full build process and a live demonstration of the robot in operation are documented in a video linked below, showing the mechanics, control system, and the slightly ridiculous end result. The system is a fully custom rail-mounted robot running on a two-meter aluminum rail. It combines CNC-machined mechanics with repurposed 3D-printer electronics and custom software. Motion is driven by four NEMA-17 stepper motors paired with MKS42C closed-loop stepper drivers and controlled by an MKS Robin Nano 1.2 mainboard from an old Sapphire Pro printer. A heavily modified version of Marlin is used purely as a generic motion engine.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The 2017 Hackaday Prize
An open-source robot that helps makers build low-cost robots without having to start from scratch.
Project Owner Contributor
Two Leg Robot
ted-huntingtonTed Huntington
The 2015 Hackaday Prize
World's First Remotely Controlled "Humanoid" Robot a.k.a Shadow Bot
Humanoid Robot
aviAvi
Additional system for Delta-Robot One to transport things into the robots workingspace
Conveyor System for Delta-Robot One
pascal-buergerPascal Buerger
A 6-DOF robot arm without a dedicated purpose. The mechanics is out of 3D-Printer and a Lasercutter. Driven by HDrives servos and time belts
"Woody" - Robot Arm out of Wood, Steel and Plastic
chrisChris
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "I Built a Robot Just to Feed My Dog", please tell us the reason.
Send message
Remove Member
