SA 3D printed box for D-Sub 9 connectors
For easily connect cables and change connector gender designed by OpenScad.
0 followers
A handy box for connecting D-Sub9 connector cables together in paralell. I use this for lab and service work for CAN and RS485 cables. The number of connectors can be changed by editing the parameter 'connN' in the scad-file. Stl files for 3, 4 and 6 connectors are available in addition to the scad file, see https://www.thingiverse.com/thing:7258532
O.A.Olsen wrote 6 days ago point
You are correct, I changed to D-Sub
Per Jensen wrote 01/05/2026 at 21:10 point
PSST: DE-9. The second letter denotes the size of the shell. a DB-connector is 25 pins wide. a DA is 15 pins, DE is 9 :)
