Project Overview
This project turns a basic energy meter into a connected, real-time monitoring system that delivers electrical metrics to the cloud and notifies you by SMS when something goes wrong. An ESP32 microcontroller reads voltage, current, power, energy, frequency, and power factor from a PZEM-004T sensor. The device publishes these readings over MQTT to a dashboard and triggers SMS alerts via a cloud API for abnormal conditions like high voltage or overload.
Why This Matters
Standard utility meters don’t let you see or react to your power usage in real time. This build provides:
Live remote monitoring with a browser dashboard
Automatic SMS alerts on electrical anomalies
Local display of readings on an LCD
Low cost and open-source code with easy hardware integration
How It Works
Sensors & Data Flow
PZEM-004T measures AC parameters using a current transformer and internal metering chip.
The ESP32 polls these values over UART (Modbus) and updates the LCD.
Readings are sent over Wi-Fi to an MQTT broker where a web dashboard displays them in real time.
If a condition exceeds a threshold (e.g., voltage spike), the ESP32 calls a cloud API to send an SMS alert.
Circuit Summary
ESP32 RX/TX ↔ PZEM-004T UART
I2C (SDA/SCL) ↔ LCD for local readouts
Power from 5 V supply
CT around live conductor for current sensing
No mains is wired into the microcontroller — the PZEM module isolates the high voltage side.
Software Highlights
Wi-Fi & MQTT setup for remote publishing
Sensor polling loop reads voltage, current, power, etc.
SMS logic triggers when thresholds are exceeded
Dashboard code (HTML + JS) connects via WebSockets to MQTT topics for live UI updates
Dashboard
The dashboard (HTML + CSS) displays real-time values for all major electrical parameters. It connects to a public MQTT broker and auto-updates UI elements as new data arrives.
Practical Use Cases
Home power monitoring with alerts
Safety fault detection (overload, unexpected drops)
Remote management of vacation homes or installations
Integration with home automation systems via MQTT.
Building Tips
Place the CT clamp only around the live wire to avoid incorrect measurements.
Ensure the LCD’s I2C address matches what your code expects (0x27 or 0x3F).
Test SMS triggers with safe thresholds first.
What You’ll Need (Quick List)
ESP32 dev board
PZEM-004T + CT sensor
16×2 I2C LCD
Wi-Fi access
Circuit Digest Cloud account for free SMS API.
ElectroScope Archive
nichod
Brian Sutherland
Nelectra
