Under constructions!
Specifications:
Input gain: 1, 10 and 100
Input coupling: AC or DC
Output impedance: 0.035 Ohm
Slew rate: 8.5V/us
Rise time: 860ns
THDN: 0.0091% BW 10Hz to >300kHz @1kHz input (Gain 1)
Features
Current monitor BNC output 100kHz bandwidth 1V/A
Differential inputs Rin ~10kOhm
Signal DC offset or modulation capable using differential inputs
Overcurrent output protection 7App
Gain Block diagram
Bode Plot
PCB 3D View
PCB Front
PCB Back
James Wilson
Sagar 001
Bud Bennett
Cool project, where did you get the case?
