WEEDINATOR 2026 Agricultural Robot
After 7 years, the project is still very much alive!
The WEEDINATOR project is focused on building a small robot to perform tasks in the agricultural realm. The hardware for the control system and the safety cameras modules is open source.
What is the WEEDINATOR?
The WEEDINATOR is a collection of modules to enable autonomous weeding of rows of vegetables by a robot tractor. It is not limited to weeding and can be adapted for planting and other functions.
What are the main components of the WEEDINATOR?
We call the 3 primary control modules Control Box 1, Control Box 2 and Safety Cameras. Box 1 is an infinitely hackable hardware system with a high end STM MCU, a set of automotive relays and automotive grade high side switches. Other sub modules in Box 1 include motor controllers and a 10 way fuse box. Box 2 can be configured in a similar way to Box 1 but would normally include a small board computer (SBC) for communication via 4G and crop detection with cameras and machine learning. WEEDINATOR Safety Cameras is a module for detecting the presence of people and a robot would normally have at least one at the front and back.
There is also a hydraulically powered cultivating (weeding) implement for towing behind the tractor.
More info to follow - watch this space!
Sponsored by PCBWay - the best quality and most reliable: https://www.pcbway.com/ . Other manufacturers exist, but we had quality issues with some of  them.
Apart from the primary control system we are working on the cultivating implement, which has an Ai camera attached that scans the grids of crops as in the video below:
This video shows how we've combined traditional, CPU intensive, Open CV type computer vision systems with modern YOLO26n Ai image inference to try and recognise, and predict, the position of grids of seedlings. The idea is to try and predict when there is a gap between the crops to momentarily stop the cultivator implement in the Y axis and quickly send a set of hydraulically driven rotating claws across the X axis, and back again. The red horizontal X axis line acts as a trigger point and when the system detects that a weighted combination of the inferred Ai driven grid center and the traditional CV grid center overlap, or are close enough to one another, a data point is added to the data array. The system is able to detect the next grid center which is useful if the system misses a trigger point. It's not perfect yet and you can see it does actually miss one prediction, but as long as it gets most of them, this should be ok.
The image below shows the major components of the WEEDINATOR system and how the different elements interact with each other:
  • Successful in row WEEDINATOR test Aug 2026
    GOAT INDUSTRIES • 08/19/2026 at 09:38 • 0 comments
    In the last test out in the field, we encountered several problems, primarily due to a software issue affecting the back claws. They moved side to side following crop lines, but they oscillated quite a bit and overshot their targets, which obviously indicated a timing problem in the code somewhere. I spent about two weeks investigating all possible causes and ended up going down a massively interesting rabbit hole. I created analysis tools on the screen, starting with thermal analysis to see if the system was getting hot and if the Jetson Nano was slowing things down. Monitoring the CPU temperatures showed they never exceeded 60.0°. I also plotted loop speed against temperature over time, which revealed absolutely no correlation, allowing me to confidently rule out thermal throttling. The system has plenty of cooling and isn't overloading the CPUs too much.
    Next, I conducted loop speed analysis by placing timers around the main camera code, which helped pinpoint the exact pieces of code causing issues. I discovered a massive random error occurring about 200 seconds into the run. At that mark, the loop duration time would suddenly double or treble. Even when the cameras stabilized and there was no movement relative to the images, the loop time failed to decrease back to normal. I made multiple changes simultaneously—always a bad idea because now I don't know exactly which one fixed it—but the issue is completely resolved. We now have a steady loop time hovering around 0.1 seconds, operating smoothly at 10 frames per second.
    All six CPUs in the Jetson Nano are behaving beautifully without flatlining at maximum capacity. This is the joy of using Gstreamer over the standard YOLO configuration, which tends to flatline a single CPU. Sharing the processing load prevents the hardware from getting hammered. While I couldn't replicate the overshooting problem in the workshop, my numerous changes make me confident it's fixed. I also increased the communication rate between the Jetson Nano and the two MCUs to 10 hertz. When we initialize the app, rapidly flashing LEDs indicate this fantastic new communication speed.
    To test the hydraulics, I fired up the app, turned on the engine, and checked the telemetry from the wheel encoders. The graph was disabled since I didn't need to see predicted plant locations just yet. With the camera loop speed running steadily, I activated the auto-weeding button. I ramped up the engine speed to get the hydraulics doing something meaningful and manually shifted the dummy plants relative to the camera. Initially, there was physical resistance—pure stiction—in the hydraulic ram. Once it overcame that stiction, the camera moved. It oscillated slightly at first because the engine revs were running a bit too high for the resolution. After turning the revs down a bit, the camera shifted almost immediately with absolutely zero oscillation. The system is now highly responsive to small changes.
    This stiction issue highlights a planned upgrade: replacing the sideways shift cylinder's crude "bang-bang" on/off valves with proportional solenoid valves. It's amazing we get any sensitivity from the current setup. The new valves cost a ridiculous £2,000, but they completely overcome stiction by keeping the hydraulic cylinders vibrating at a specific frequency, ready to move in either direction. This will provide instantaneous, precise movements down to less than a millimeter without needing to manage engine revs. Furthermore, these proportional valves are necessary to fully utilize the retractable draw bar. That mechanism uses encoder data to momentarily stop the wheels dead, allowing the claws to perform a precise sideways cultivation wiggle to weed the small gaps directly between the crops.
    Finally, we returned to the field for a proper test. I engaged the auto-weed system and recorded the GUI interface to capture exactly what the computer was seeing. Moving forward slowly, the machine immediately began making...
  • Plant Tracker Testing
    GOAT INDUSTRIES • 08/02/2026 at 09:13 • 0 comments
    We are testing line-following on the WEEDINATOR with printed leaf cards. The system pairs YOLO machine learning with traditional algorithms to detect leaves and guide the claw. Lighting is critical; a cold blue light works perfectly, while yellow light causes total detection failure.
    Mechanical & Field Performance
    The camera and claw are physically linked on gantries. Because the hydraulic system lacks dynamic pressure regulation, running it too fast causes side-to-side oscillation. By adjusting the tractor's engine revs, we calibrated the tracking speed to eliminate this in the workshop. During field tests, the system performed exceptionally well despite harsh sunlight and shadows. Although the hydraulics still caused minor overshooting, the robot quickly stabilized, tracked the row accurately, and executed its weeding maneuvers. The speed issue is going to be easily solvable, making this a highly successful test run.
  • Promo Video
    GOAT INDUSTRIES • 06/18/2026 at 11:56 • 0 comments
  • WEEDINATOR Official Soundtrack
    GOAT INDUSTRIES • 06/14/2026 at 20:46 • 0 comments
    The WEEDINATOR project now has it's own soundtrack !! Every robot should have one:
    WEEDINATOR sound tack
    WEEDINATOR sound track
  • WEEDINATOR Test June 13 2026
    GOAT INDUSTRIES • 06/13/2026 at 21:20 • 0 comments
    In today's test, we are weeding carrots using a robot programmed via an app database to navigate down the crop bed. The tractor waits at the beginning of the bed. After fetching the specific crop bed data (dated April 1st), the root system materializes, and it is added to the overall route sent to the table for the machine to pick up. The complete route, which includes initial turning waypoints, is uploaded to the cloud for the machine to download.
    For autonomy, the robot uses GPS to control steering and navigate with centimeter-level accuracy, removing the need for manual radio control steering. However, because there is currently no operating camera system to detect the carrot lines, the claws must be manually adjusted along the Y-axis. Recent design modifications include a swept shape at the bottom of the claws to enable self-cleaning. In a previous test, debris became glued to the end of the claws, increasing their diameter and slightly affecting the crops. It is hoped this swept design will perform better. Additionally, needle valves were installed on the Y-axis and Z-axis hydraulic cylinders to allow much finer flow control rather than pressure restriction. These are preset and do not require ongoing adjustment. In the long term, a Y-axis bypass is desired for in-row weeding, but the system is currently restricted to semi-automatic control testing.
    When put into gear, the machine moves infinitesimally slowly. The bright sunshine makes viewing the screen difficult, though passing clouds occasionally improve visibility and filming conditions. Manual adjustments are made to move the claws slightly to the left and right. Increasing the speed slightly confirms all three claws are operating deep within the soil. The control panel indicates a GPS speed of 0.1 m/s (100 mm/s), which is an ideal speed for testing. A minor loss in speed occurred because a front tire rolled over the bed during a previous trial, which is not the fault of the current run. The system has previously run at 50 mm/s, but that proved too slow and boring for video purposes. Though this carrot bed had never been mechanically weeded before, it is quite level. The claws create a highly accurate, manicured surface resembling a CNC machine. While side-to-side tilt adjustments are available, they are largely unnecessary, even when the right-hand claws temporarily rise before re-entering the soil to pull up plenty of weeds. The needle valves restrict vertical motion substantially, providing excellent sensitivity; adjustments to height and width are barely visible, causing only momentary pauses in claw rotation as the flow divider valve struggles to instantaneously divide pressure.
    The test on the carrot bed was 100% successful with no crop damage until reaching the very end of the bed, where the layout becomes scrappy and a chunk of carrots was accidentally taken out. At the end of the bed, the claws are turned off and lifted along the Z-axis before driving forward to avoid bending the 20 mm bar claws. Inspecting the stopped machine reveals that the self-cleaning swept claw theory is not working 100%, as a significant amount of debris remains attached to the ends. A potential solution is adding a brush to clean the claws as they spin. Because the debris did not cause problems during this run, a second test was initiated on a bed of onions without cleaning the claws to see if the accumulation worsens or self-cleans.
    The onion test runs faster than preferred—estimated between 150 mm/s and 200 mm/s. Constant manual sideways adjustments are required at this speed to avoid destroying the crops. The claws remain deep in the soil, and only one onion is wiped out, which is acceptable since previous tire tracks had already damaged a few. Because these onions have been grounded for a while, their established roots allow them to withstand minor claw impacts.
    The onion bed is growing nicely with no obvious pests, unlike a parallel bed planted earlier in the season that was...
  • Testing the Weeding System in Semi Auto Mode
    GOAT INDUSTRIES • 05/11/2026 at 10:53 • 0 comments
    Video transcript:
    I'm going to try and do a test of the basic reading functionality with this robot with its cultivator attachment on it. Today it's quite sunny which makes filming quite difficult and to introduce you to the touch screen. The new touch screen. Oh, look at that. So, let's just put the machine out of gear. It's safe. And restart the app. So, it picks up the waypoints it's going to use. Restart. Yes, let's restart. Oh, look at that. So, I don't know if you can see there's should be looking at 24 waypoints. Look at the accuracy. That's quite useful. 16 mm. Got various encoder readouts there. Real encoder, horizontal encoder on the instrument. Real encoders on the instrument as well. The drawbar encoder is on the drawbar. We've got an extendable drawbar which put it into auto mode here. Should help. There she goes. Just going to slowly get it into position on the bed before I turn the hydraulics on. It drives so lovely and slowly. It's fantastic. Absolutely brilliant. Look at that. I think it goes at something like 100 mm/s, which sounds really fast, but it's millimeters per second. Actually goes what's the speed of this at the moment? It's going up about 75 mm/s. Fantastic. It's what we want when we're testing machinery. Drive it really slowly. I wonder if I got the still on the front motor. So, whilst it's just edging onto the bar, use the multiplexer to engage the rear hydraulics. So, if I did that now, it should operate. Let's try running the claws. There she goes. Quite slow at the moment because the engine revs are quite slow. When it gets in position, I'll turn the revs up and get some speed on the claws. But yeah, everything's really nice and well controlled, which is really good. Let's stop the machine. There she goes. It's not actually on the bed properly yet because it takes a little bit of time for it to align. So, it's quite likely that started weeding now. We're going to whip up some crops. But we can start doing like a bit of a simulation. I don't want to destroy the crops. That's all. I know that the wheels aren't in position, but let's just speed it up to start with. We'll lower it down a little bit. And when I got a bit of confidence, I'll lower it down a bit more. I just don't want to destroy my lovely crops, which is what it's going to try and do. But mostly because I'm just trying to film it at the same time. It's just really hard. So, let's get that speed going nice and slowly. There she goes. Remember, this is literally the first test, so things are going to be awkward and I'm filming it. It's really difficult. So, I'm controlling the claw to get it in position. When I feel confident that I'm not going to just destroy the crops, I'll lower it down a bit. It's looking good. It's looking all right. So, let's try lowering it down a little bit. Bit close. It's in the soil a little bit. Let's ramp it up a bit as she goes. I don't even know if you can see this on film. Sunshine's so bright. It's not a good day filming. Right. So, I'm feeling a little bit more confident now. I'm going to lower it into the soil. Look at that. There she goes. It's weeding. Nice. There she goes. It's great. I don't have to control the steering. It's all the steering side of it. It's all working really well. So, you got centimeter precision on that steering, which is absolutely fantastic. So, it's quite deep in the soil. I think it's uprooting any weeds that are in there. It didn't even need weeding because these crops were only planted yesterday. But the whole idea this season is for this stuff to be literally a test bed. There it goes. I'm not adjusting it at all on the hydraulics. Maybe I'll just move that a little bit. It's claws. Even though they look quite kind of deadly, they don't really seem to bother the plants too much. They're not ripping the plants out even though, like I said, they were only planted yesterday. So, the roots aren't holding them in very much. So, it's good. It's not pulling any leaves off. I'm...
  • Crop Grid Detection
    GOAT INDUSTRIES • 01/26/2026 at 23:56 • 0 comments
View all 7 project logs
  • 1
    WEEDINATOR Ai Camera Control Box (Box 2)
    Weedinator Camera & Control Box Components
    • Enclosure & Mounting
    • Glands & Seals
      • Split Glands: Icotek KEL-ULTRA flex Large Split Glands for connectorized cables
      • M12 Glands: IP68 M12 Polyamide Cable Gland (Light Grey)
      • M16 Glands: IP68 M16 Polyamide Cable Gland (Light Grey)
    • Cooling & Environment
      • Vent Gland: IP66 Air Vent Gland, M12 x 1.5 (Prevents condensation)
    • Power Distribution
    • Voltage Regulation (On-Board)
      • 5V Regulator: D2-Pack 5V Voltage Regulator (LM2576 or similar)
      • 3.3V Regulator: D2-Pack 3.3V Voltage Regulator
    • Motor Control
      • Motor Driver: Cytron 10A Dual Channel Motor Driver (MDD10A)
    • Computing & High-End Vision
      • Jetson Nano: NVIDIA Jetson Nano Developer Kit
      • Vision Interface: VL-GM2-8CAM-RPI22 (GMSL2 8-Camera Hub for RPi/Jetson)
      • Camera Units: VLS-GM2-AR0234-C-S83-IR (Global Shutter GMSL2 Cameras)
        • Supplier: VizionCam
      • Coax Cables: Vizionlink-COAX1-Cable (0300 and 0500 lengths)
    • Navigation & Logic
      • GNSS Receiver: SparkFun GPS-RTK2 Board - ZED-F9P (Qwiic)
      • Level Shifter: SparkFun 4-Channel Logic Level Converter
    • Connectivity & Fabrication
    Step by step video instructions on how to assemble the components onto the WEEDINATOR MCU PCB.
    This guide covers the assembly process for the WEEDINATOR MCU PCB, moving from precision surface-mount work to robust through-hole connectors.
    SMD Population and Stenciling
    The assembly begins with the surface-mount device (SMD) components. Precision at this stage prevents logic errors later.
    • Voltage Regulators: Install the 5V and 3.3V D2-pack regulators in the top-left corner.
    Note: Ensure the 3.3V component is the correct variant; several D2-pack components look identical but have different pinouts.
    • Stenciling: Use a microscope to align the stencil perfectly.
    • Maintenance: Clean the stencil immediately after use with isopropyl alcohol. If solder paste hardens in the fine apertures, it is nearly impossible to remove.
    • PCB Quality: High-quality fabrication (like PCBWay) is recommended. Lower-tier boards may have defects, such as pins pre-filled with solder, which complicate assembly.
    Component Identification & Reflow
    Before heating the board in the reflow oven, double-check component values and polarities.
    • Resistors (0603): Distinguish between 10k and 1k resistors. The 1k resistors typically have a "0" marking, while 10k resistors require a microscope to read the code.
    • LEDs & Buzzer: * LED Cathode: Look for the tiny green mark on the LED to identify the cathode.
      • Buzzer: Match the orientation of the writing on the buzzer to the silk-screen on the PCB.
    • Capacitors: Install the black crescent capacitors to stabilize the voltage supply.
    • Regulator Pins: On D2-pack regulators, the middle pin may not touch the PCB pad. This is acceptable as the large ground tab at the back provides the primary electrical and thermal connection.
    Through-Hole Components & Headers
    Once the SMD work is reflowed, move to through-hole soldering.
    • SBUS Inverter: Solder the ZX450 NPN transistor. The PCB graphics clearly indicate the flat-side orientation.
    • MCU Headers: 1. Tack-solder only the end pins first. 2. Slide the MCU onto the headers to check alignment. 3. Warning: Never force the MCU onto wonky headers; this can crack the silicon chip. If the headers are out of alignment, reheat the end pins and adjust until the MCU "clicks" into place easily.
    MCU Fitting & WAGO Connectors
    • Installation Hack: Use a small amount of WD-40 on the header pins. It significantly reduces the friction required to seat or remove the MCU.
    • Safe Removal: When prying the MCU off, use a screwdriver gingerly to avoid "banana-shaping" (bending) the PCB.
    • Terminal Blocks: This board uses orange WAGO-style spring connectors rather than traditional screw terminals.
      • They are more reliable under vibration.
      • Like the headers, solder only the ends first to ensure they are seated flush against the PCB before finishing the remaining pins.
    Final Setup and Commissioning
    • Grounding: Solder all available ground connectors—the more ground paths, the better the signal integrity.
    • GPS Support: Install headers for the daughterboard, which supports dual Ublox Series 9 units for precise heading data.
    • Hardware Jumpers: You must remove jumpers SB57 and SB31. This disables the Ethernet pins to free up PA1 and PA7 for system use.
    • The "Smoke Test":
      1. Check the 5V and 3.3V rails with a multimeter.
      2. Power the board with preloaded test code. A successful build will trigger an audible beep from the buzzer and a flash from the LEDs.
    Populating the 20 Channel High-side Switch PCB
    PCB Design and Enclosure Logistics
    • PCB Color Choice: For this project, white PCBs were specifically chosen over black. In a closed enclosure, white surfaces reflect ambient light, making it much easier to see the wiring and components during maintenance.
    • High-Side Switches vs. Relays: * High-Side Switches: These are used for components like flashing beacons and hydraulic solenoid valves.
      • Automotive Relays: Used for higher-current loads (up to 40A) such as engine glow plugs and starter motors.
    Solder Paste Application & Stenciling
    Using a stainless steel stencil is the most efficient way to populate this board, especially given the "massive" footprint of the high-side switch components compared to standard surface-mount parts.
    • Solder Paste Freshness: Ideally, solder paste should be less than six months old. While these large components are more forgiving, fresh paste is essential if your board includes smaller 0603 components.
    • Stencil Technique: 1. Secure the PCB and align the stencil. 2. Apply the paste with a squeegee, ensuring every aperture is filled to the top. 3. Critical Step: Lift the stencil vertically and carefully. Sliding it will smear the paste and cause solder bridges (shorts).
    • Maintenance: Always clean the stencil with isopropyl alcohol immediately after use to prevent paste from hardening in the apertures.
    Reflow Soldering and Manual Rework
    The size of this PCB was maximized to fit the reflow oven, which presents some thermal challenges at the board's perimeter.
    • Edge Component Inspection: Reflow ovens often have "cold spots" near the edges. Components in the center of the board usually come out shiny and well-soldered, while those near the edges may not reach full liquidus temperature.
    • Heavy-Duty Rework: To fix incomplete solder joints on the large component tabs, a high-wattage soldering iron (e.g., 450W) is used.
      • The massive tip stores enough thermal mass to heat the large copper tabs quickly.
      • Heat the tab until the solder becomes "runny" and flows through the joint for a solid mechanical and electrical connection.
    Final Finishing and Connectivity
    • Post-Solder Cleaning: Scrub the board with isopropyl alcohol and a wire brush. This removes flux residue and dislodges any "solder balls" or tiny blobs that could cause a short circuit.
    • Quality Control: Every joint is tested with a continuity meter to ensure there are no errors before the board is powered.
    • Connectors: The final step involves installing WAGO spring connectors. These are preferred over screw terminals for their reliability in high-vibration environments (like a robot or tractor).
    uses on the physical layout and enclosure preparation, ensuring that all sub-assemblies fit within the footprint while maintaining signal integrity and accessibility.
    Enclosure Layout and Component Placement
    The current prototype assembly (Box Two) includes the 20-channel high-side switch PCB, the MCU board, a fuse box with LED fuses, the Jetson Nano, and the camera de-serializer board.
    Key Layout Considerations:
    • Space Constraints: Because this unit (Box Two) is designed to sit flush against "Box One" on the robot, one end of the enclosure must remain completely blank. No components or connectors can protrude from that side.
    • Thermal Management: Cooling fans are positioned in opposite corners to create cross-flow.
    • EMI Interference: It is crucial to keep the cooling fan away from the MCU. Fans can cause signal degradation and electromagnetic interference (EMI) if they are too close to sensitive logic circuits.
    Cable Entry and Gland Strategy
    I am using a modular panel system to organize external connections. This allows for a clean, organized entry point for various wire gauges.
    • Gland Sizes: I’m primarily using 12 mm glands for standard wiring (supporting up to 12 holes in a tight but functional cluster) and 16 mm glands for larger cables.
    • Split Gland System: For USB and camera cables, I’m using "tech glands" (split glands). These are essential for FAKRA connectors found on the cameras; since these connectors are permanent, they cannot be threaded through standard holes. The split gland allows the cable to be slotted in and then sealed.
    • XLR Fittings: I’m using XLR-style housings for the Jetson's DisplayPort and USB ports. While handy for temporary monitoring, they are more prone to shaking loose than fixed glands, so they are reserved for non-critical or temporary connections.
    User Interface and Monitoring
    The exterior of the box features several "quality of life" components for field operations:
    • Voltmeter: Provides an immediate visual check that the alternator is charging and the battery is at the correct voltage.
    • Momentary Switches: Useful for triggering specific software routines or safely shutting down the Jetson/single-board computer.
    • DisplayPort: Externally accessible for monitoring the Jetson's output during debugging without opening the weather-sealed box.
    Next Steps: Enclosure Fabrication
    Now that the internal mapping is complete and the clearances are verified, the next step is to disassemble the boards and begin the drilling process.
    • Tools: I’ll be using hole saws to create the entries for the glands and XLR fittings based on the marked-out patterns.
    • Orientation: Most cables will be routed toward the end of the enclosure that faces the hydraulic solenoid valves on the robot.
    Project Progress: Wiring and Housing Preparation
    Drilling and Enclosure Strategy
    I have finished drilling all the necessary holes in the enclosure. I’ve intentionally drilled about 50% more holes than currently required. In my experience, trying to go back inside the system to rewire or add features later is an absolute nightmare, so having those spares ready is critical.
    I’ve included a large slot for icote split glands. These are great for Ethernet and USB cables because they allow you to pass cables through without having to remove the connectors or couplings. Speaking of connectors, I’ve learned the hard way never to mount the connectors directly into the enclosure holes; it's much better to use a system where the couplings stay outside the box.
    Critical Technical Note: Brass Inserts
    If you are using brass inserts (specifically the type from RS Online), the drill size is absolutely critical.
    • Required Drill Bit: 5.7 mm
    • Warning: If you use a smaller bit, such as 5.5 mm, the screw will lock into the insert during installation, and you will never get it out again.
    Component Assembly and Labeling
    I am now ready to assemble the internal components. The fuse box can stay on, and I’ll be using standoffs for the rest of the parts.
    I’m currently installing a 20-channel high-side switchboard. I have already wired the eight channels on the lower PCB. Proper labeling is essential here; every logic cable and board position is labeled (e.g., "Relay 1," "Relay 2"). Without these labels, it would be impossible to keep track of the system.
    Current Status and Next Steps
    The total channel count is now at 28. The system is expandable; I could stack another PCB to add another 20 channels if needed, though I haven't reached that requirement yet.
    The logic cables are tucked in and routed to one side to keep the layout tidy. I am going to finish connecting the remaining wires and fasten the board down before moving on to the next phase.
    PCB Layer Cake: Assembly and Cable Management
    Layer 1: Switchboard and Power Supply
    The board is currently partially wired with eight channels completed and twelve remaining. I have meticulously labeled everything to ensure clarity during assembly.
    Cable Routing Strategy:
    • Rear Routing: All wires are tucked neatly behind the board rather than across the top.
    • Hinge Accessibility: By keeping the top clear, the board can "hinge" upward if you ever need to access components underneath (like replacing relays) without disconnecting the entire system.
    • Power: The 12V supply comes from the fuse box through a general-purpose connector. While some pins are currently unused, they are ready for future expansion.
    Layer 2: Logic and MCU Integration
    We are now moving into the "layer cake" phase of the build. The logic cables are wired up on one side—I’ve given them a "tug test" to ensure they are secure.
    Cable Sizing and Loads: The wire gauge is strictly chosen based on the current load:
    • 0.75 mm²: Used for the remote connector (low current for hydraulic solenoids and warning beacons).
    • 1.5 mm²: Used where cables double up.
    • 2.5 mm²: Used for groups of four connectors and the main common lines routing back to the base.
    Enclosure Constraints and Flexibility
    Space is becoming tight on two sides of the enclosure because this unit butts up directly against "Control Box 1." Consequently, I’ve had to leave eight channels unwired for now, though they remain available for immediate use if needed.
    Split Gland System: I am using a flexible rubber grommet/split gland system for the network and camera cables.
    • No Cutting Required: This system allows you to pass fat camera cables through the enclosure without cutting the connectors off.
    • Scalability: Each grommet can potentially hold two wires, doubling the capacity of a standard 10-way entry.
    • Dedicated Ports: I’ve reserved four glands specifically for the encoder wires and motor controllers coming off the main MCU board.
    Next Steps
    The MCU board is ready to be bolted down onto the standoffs. Once secured, I will begin routing the long logic cables to their respective terminals on the far side of the enclosure.
    Power and Motor Control
    We’ve made significant progress on the motor wiring and power monitoring:
    1. Wiring Gauges: The motors are wired with 1.5 mm cables, supported by a 2.5 mm main feed to the master switch.
    2. Voltage Monitoring: I’ve installed a handy voltage meter. This is vital for monitoring the health of the battery and confirming the alternator is outputting its expected 14.8V.
    3. Motor Control: The PWM and direction connections use pink color-coded cables routed under the board. These control a dual-channel motor controller, which currently operates a prototype pan-tilt mechanism for our safety cameras.
    4. Motor Polarity: The motor cables are twin-core; if the direction is reversed, simply swapping the connections will fix it.
    Jetson Nano & Vision System
    This box serves as the hub for our vision and processing via the Jetson Nano.
    1. FAKRA Vision System: We are using TechNexion FAKRA cameras rather than standard Raspberry Pi cameras.
    2. Durability: They are waterproof and support long cable runs (up to 15m).
    3. Configuration: We have three connections—one for the front safety camera, one for the rear, and one dedicated to crop detection on the cultivating machine.
    4. Performance: Currently achieving approximately 15 FPS per camera.
    5. Connectivity: * A DisplayPort cable is routed to the exterior for screen communication.
    6. Spare USB ports are available for a wireless keyboard/mouse.
    7. An icote split gland system is used for all USB, Ethernet, and camera cables to avoid cutting connectors and maintain waterproof integrity.
    MCU Communications and Logic
    The Jetson Nano acts as the "Master," communicating via USB (the blue cable) to the local MCU and the MCU in Box One.
    1. Logic Level Shifting: Since the encoders operate at 5V and our system runs at 3.3V, I’ve integrated logic level shifters.
    2. Timer-Based Pins: The MCU is very specific about which pins it uses for encoders and PWM because they are timer-based. We have identified three encoder-compatible pins and are auditing the manual to find more.
    Final Weatherproofing
    To wrap up the hardware side:
    1. The de-serializer board is confirmed to be 14.8V tolerant, making it safe for direct alternator power.
    2. I am installing blanking grommets in all unused holes. This is a small but critical step to keep insects and debris out of the enclosure, which could otherwise cause shorts as they grow or nest.
    MCU Configuration and Pin Mapping
    Encoder and PWM Trade-offs
    I’ve integrated four-core cables for the encoder channels. While an initial LLM analysis of the datasheet suggested a theoretical maximum of 10 encoders and 4 PWM outputs, there is a clear trade-off between these functions. Through experimental verification, I’m aiming for a balanced configuration—likely 8 encoders and 6 PWM outputs.
    The system currently uses logic level converters to handle 5V encoders. Note that 12V encoders would require custom wiring in the provided "hackable space" on the board.
    Current Pin Assignments: | Function | Component | Pins | | :--- | :--- | :--- | | Encoder 1 | Input | PA0, PA1 | | Encoder 2 | Input | PE9, PE11 | | Encoder 3 | Input | PD12, PD13 | | Encoder 4 | Input | Testing in progress | | PWM | Speed Control | PE4, PA5, PC7 |
    Modular Hardware Adaptations
    The beauty of this system is its modularity. Although this is "Box Two" (the Camera Box), it can be adapted depending on the rig requirements:
    1. Motor Controllers: Currently, I only have one dual-channel controller for the pan-tilt cameras. However, there is room to bolt on 3 to 4 single-channel controllers if needed.
    2. GPS Integration: While this box doesn't use it, the board is designed to support a bolt-on GPS system.
    3. Stacking: There is potential to raise the PCBs using standoffs to insert additional layers, such as extra motor controller boards, above or below the current stack.
    Physical Clearances and Enclosure Fit
    With the lid on, the FAKRA camera cables present a height restriction. They exit the de-serializer board vertically, meaning the Jetson/Nano PCB stack cannot be raised much higher without putting stress on the connectors or requiring a sharp bend in the cables.
    I estimate there’s about 30mm of vertical play available, which might just be enough for one extra layer of motor control if I’m careful with the routing.
    The Full Rig Setup
    In the final configuration, this Camera Box (Box Two) will sit alongside Box One. Box One is identical in size but omits the Jetson and de-serializer board to provide maximum real estate for heavy-duty motor controllers and the primary GPS system.
  • 2
    Assembling Box 1, the Engine and Vehicle control Box
    Box 1 Baseboard Assembly
    I am soldering the Box 1 baseboard, which handles engine starting, glow plugs, steering, and throttles. To keep boxes less cluttered, hydraulic actuator controls and cameras were moved to Box 2
    High-Current Power Hack
    • Standard PCB relay holders and traces can't handle high current—40A for the starter and 20A for glow plugs.
    • The Solution: I manually solder heavy copper bus bar wires across the back of the PCB to reinforce connections.
    • Soldering: A 450W iron is used for these heavy connections.
    Key Components
    • Switches: Eight L293D motor controllers are DIP mounted for easy hand-soldering.
    • Control: Relays are controlled via these switches because MCU pins cannot provide enough current for the coils.
    • Power: A 5V regulator with capacitors provides stable logic power.
    • Sensors: An optional current sensing system helps prevent motor burnout during stalls.
    • Expansion: Supports stacking Cytron motor controllers and an add-on board for 16 extra relays.
    Standoffs and Mechanicals
    • Precision: I use a stencil for correct solder amounts on small components.
    • Clearance: Standoff lengths (30mm–50mm) are critical as the MCU is underslung.
    • Mounting: Four-pronged 4mm captive nuts secure the board using pre-drilled holes.
    Assembly Tips
    • Wiring: I reversed terminal blocks to face inward for better cable access.
    • Fragility: Be gentle; thin PCB traces rip easily if you pull on terminals.
    • Testing: If damaged, bridge a connection from the resistor to the screw terminal
    Populating a 20-channel high-side switch PCB from PCBWay. Using white PCBs for this project is helpful because they reflect light inside the enclosure, making it much easier to see what you are doing compared to dark or black boards.
    Component Overview
    • High-Side Switches: These are ideal for components like flashing beacons and hydraulic solenoid valves.
    • Automotive Relays: While not populated today, these typically go together with this build to control high-current engine functions like glow plugs and starter motors (up to 40A).
    • Stencil Usage: Using a stainless steel stencil makes application much easier and more precise than doing it by hand.
    • Alignment: The parts on this board are relatively large, making it simple to line up the stencil.
    • Solder Paste: It is important to use fresh solder paste; if it has been sitting for more than six months, it can "go off" and lose effectiveness, especially for fine components.
    • Technique: Apply the paste with a squeegee, ensuring all holes are filled to the top. The stencil must be removed vertically to avoid smearing.
    Soldering and Reflow
    • Reflow Oven: The PCBs were designed to be the maximum size that fits into the reflow oven.
    • Edge Issues: Sometimes the oven fails to properly solder components near the edges of the board.
    • Manual Touch-ups: Any incomplete joints at the edges can be finished by hand.
    • Heavy-Duty Iron: A 450W soldering iron is used to heat the large tabs on the high-side switches to ensure the solder flows through correctly.
    Finishing and Testing
    • Cleaning: After soldering, the board is scrubbed with isopropyl alcohol and a wire brush to remove any stray solder blobs.
    • Verification: The board will undergo a final test with a continuity meter before attaching the WAGO connectors.
    instructions for assembling the components onto the WEEDINATOR MCU PCB.
    Initial SMD Population and Stenciling
    • Voltage Regulators: Start at the top left with the 5V and 3.3V surface mount regulators. Ensure you use the correct D2 pack components for the 3.3V line, as wiring configurations vary.
    • Optional Circuits: The board includes options for a CAN bus and an SBUS circuit, alongside standard 0603 LEDs.
    • Debugging Tools: Voltage dividers (using 0603 resistors) and a buzzer are included to assist with commissioning and system debugging.
    • Stencil Preparation: Use a microscope to align the stencil for precise solder paste application.
    • Cleaning: Clean the stencil with isopropyl alcohol immediately after use to prevent the paste from hardening.
    Component Identification and Reflow Preparation
    • Resistor Identification: Carefully distinguish between 10k and 1k resistors. The 1k resistors are marked with a "0," while the 10k resistors may require a microscope to read.
    • LED Orientation: Tiny green marks on the LEDs indicate the cathode (negative) side.
    • Buzzer and Capacitors: Align the buzzer according to the positive mark or PCB graphics. Install the 5V and 3.3V regulators; the ground tab provides the primary connection. Include black crescent capacitors to stabilize the voltage supply.
    • Inspection: Use a magnifying glass to verify all placements before placing the board in the reflow oven.
    Through-Hole Soldering and MCU Headers
    • Transistor: Install the ZX450 NPN transistor used for the SBUS signal inverter, following the graphics on the PCB for correct orientation.
    • Header Alignment: When installing male/female headers, solder only the ends first.
    • Fit Testing: Slide the MCU board onto the pins to ensure they are perfectly vertical before soldering the remaining pins. This prevents physical stress or cracking of the MCU chips.
    Fitting the MCU and Terminal Blocks
    • Installation Hack: Use a practice MCU and a small amount of lubricant (like WD-40) to help the board slide onto the headers without stress.
    • Removal: If you need to remove the MCU, use a screwdriver to prize it off gingerly to avoid bending the board into a "banana shape."
    • WAGO Connectors: Use high-quality orange WAGO connectors instead of screw terminals. Solder only the ends first to ensure they are seated flat against the PCB before finishing the row.
    Final Connections and Testing
    • Grounding and GPS: Solder all ground connectors and the headers for the GPS daughterboard, which supports two Ublox Series 9 units for heading data.
    • Jumper Modification: Remove jumpers SB57 and SB31 to reconfigure the pins for PA1 and PA7 usage instead of Ethernet.
    • Power Test: Verify the voltage regulators with a multimeter to confirm stable 5V and 3.3V rails.
    • Functional Test: Preload test code to confirm the system beeps and flashes the LEDs upon startup.
View all instructions
blaise2410 wrote 05/06/2026 at 20:49 • point
It's an impressive project congratulations! Nearly exactly my dream to seed and hoe corn by robot. On my opinion the most delicate point is to make the vehicule able to follow a row crop in the most wide kind of conditions, including that some parts of the row could be missing (ground too dry to make it grow, eaten by crowds, slugs...etc), to detect the end of the row and to turn on the next row. From this, you can already perform seeding and hoeing outside the row  which mean it's already operational for some purpose, then other possibilities are only limited by the tool development...
GOAT INDUSTRIES wrote 05/07/2026 at 12:03 • point
Thanks! As the project continues, the weeding / planting / harvesting functions will improve. Just need to optimise the conditions for the earlier trials.
