💡 What is it for?
- Ambient Lighting: FULL mode with all 16 bright yellow LEDs illuminated.
- Connected Clock: CHASE mode displays minutes.
- Synchronized automatically via NTP server.
- Hour Signal: A special animation triggers every hour (CHASE mode only).
- Fully upgradeable (create new functions, replaceable LEDs).
- Educational Platform: A perfect playground for MicroPython and circuit assembly.
🛠️ Technical Snapshot
- Logic: Raspberry Pi Pico 2W
- Drivers: 2x TPIC6B595 Power Shift Registers (high-current sink)
- Display: 16x 2500 mcd Yellow LEDs in a circular array
- Connectivity: Wi-fi Web Server via Microdot (Remote control & Log monitoring)
- Retro design and no case to showcase the PCB & electronic components
- PCB dimensions: 165 mm high x 110 mm wide
- PCB stand: Material and color are up to you, as you'll be printing it yourself
- Efficiency: Ultra-low consumption (0.18 Wh to 1.25 Wh)
👷 How to build it?
- Buy the PCB on Tindie (complete kit will be available perhaps later, depending on demand).
- Print your PCB stand from the provided 3D files.
- Assemble and configure your board according to the documentation provided.
- Upgrade the code as desired and share your creations if you wish.
📖 The Story
Most modern LED projects rely on pre-assembled surface-mount components (SMD) and smart LEDs like WS2812Bs. While convenient, they often hide the "magic" of how electronics actually work.
I created the ML01 to go back to the basics:
- The Beauty of THT: I chose through-hole components to make the project 100% repairable and perfect for those who find soldering therapeutic.
- Power Shift Registers: Instead of "smart" LEDs, ML01 uses two TPIC6B595 power shift registers. This is a deliberate choice to teach how to expand microcontroller I/O and handle higher current loads.
- Next-Gen Brain: By using the Raspberry Pi Pico 2W, the board has enough power to run a local web server (Microdot) while maintaining ultra-low power consumption.
- Dual Control: You can toggle between "FULL" mode and "CHASE" mode using physical buttons or any browser on your network for remote-control.
- This project is fully documented, even complete beginners should be able to complete it by following the assembly and configuration guides on my GitHub repository.
📜 Licenses and philosophy
This project is part of a balanced open-source model.
- Firmware: MIT License
- Documentation & 3D Models: Creative Commons (CC BY-NC-SA 4.0)
- PCB Design: Proprietary to ensure project sustainability
🤝 Contributions & Collaboration
Your contributions to improving the firmware and documentation are welcome. Thank you in advance for reporting any bugs or new ideas.
I am also open to any form of collaboration with other passionate makers in order to explore the possibilities of cross-promotion, hardware, etc.
RELEASE255
SUF
Arnov Sharma
pcadic
