Supported Models:
Levoit purifiers – custom firmware, no hardware modifications needed:
Levoit humidifier:
Levoit – hardware modification required:
Philips / Versuni – add your own ESP32 (stock module is locked):
Other manufacturers – external projects, listed for completeness:
Cloud-free without ESPHome: around 57 Philips / Versuni models use an MXCHIP Wi-Fi module that cannot run ESPHome, but their stock firmware speaks encrypted CoAP on your LAN — so they can be driven entirely locally, without opening the case. See the CoAP section for the model list.
Key Features Across All Models:
Getting Started:
See the ESPHome Air Purifier Project documentation for complete details, including:
