Single Chip Computer running BASIC-52
We have already seen the power and possibility of running a Single chip computer using CH552. The main limitation with CH552 is the speed of the computer and the useful internal RAM available to the user.
The maximum clock speed of CH552 is 24 MHz. The internal xRAM available to the user is 1kB. Within this 1kB xRAM, the BASIC-52 will allocate around 512 bytes of xRAM for STACK and to keep many other status bits at RAM. We can refer to BASIC-52 manual for more details.
Enhanced core E8051 based CH558T microcontroller:
The CH55x family consists of CH551, CH552, CH554, CH558 and CH559.
The CH558 and CH559 comes in T & L package which consists of more pins(20 & 48), capable of running at 48 MHz and having more internal xRAM of 4kb and 6kB respectively.
Wireless Bluetooth Connectivity:
For serial communication and keyboard, we need to connect the single chip computer to a PC or Phone. But once we connect it to a phone or PC, we can not change the connection easily.
Instead if we connect the PC or Phone to the Single Chip Computer through a wireless connection using Bluetooth, we can seamlessly transfer the connection. There is no physical connection so we can keep the Single Chip Computer anywhere we want. Even we can keep the computer next room. Only requirement is the range of the bluetooth. We can also keep the computer of a robot or any enclosure without any visibility.
CH558T - SSOP20
If we notice carefully on the above pinout, we can notice PORT3, PORT4 and PORT5 pins are used. We can not directly access any of the PORTs except PORT1 using BASIC-52. So it is easy to go with 20 pin SSOP20 package than 48 pin QFP48 package.
If we have either CH558 or CH559 in any of the package should work.
FIRMWARE:
The source code assembles without any error with Atmel's C51ASM assembler in windows10/11 . C51ASM assembler is available from the Microchip website.
There are two changes made to the original file. Since we are going to use the IC at 48 MHz, the default frequency of BASIC-52 source code changed to support 48 MHz. This will help when we execute any time or timer dependent code.
Original code for 11.059200 MHz is
;CONSTANTS
XTALV:    DB    128+8        ; DEFAULT CRYSTAL VALUE
    DB    00H
    DB    00H
    DB    92H
    DB    05H
    DB    11H
 Current code for 48.000000 MHz is
;CONSTANTS
    DB    00H
    DB    00H
    DB    00H
    DB    00H
    DB    48H
The other change is CH558 uses 4kB internal xRAM compared to CH559 which uses 6kB of xRAM. The range of the internal xRAM is different for CH558 from CH559. The xRAM range for CH558 ranges from 0000H to 0FFFH. So the ERAMEND EQU 0FFFH. This is also corrected to report the proper available memory.
;=== CH558 Added =====
ERAMEND    EQU    0FFFH ; EX-RAM last addr (4KB)
;=== CH559 Added =====
;ERAMEND EQU    017FFH ; EX-RAM last addr (6KB)
CONNECTION:
We need just two wires to the Single Chip Computer namely VCC(+5V) and GND. For this purpose small micro USB breakout board is used for easy connection. We can use any of the available connector or directly connect two wires with correct polarity.
CH558 requires just 4 connections. VCC, GND, Tx and Rx
Bluetooth module requires 4 connections. VCC, GND, Tx and Rx
Some of the Bluetooth modules may support only 3.3V logic level signals. In that case we need to reduce the Tx signal from CH558 to 3.3V for safe and reliable operation.
I2C, SPI and other legacy functions may share the same pin. Please check the pin for any conflict with other functions. We can re-assign the pins and assemble the source code to avoid any conflict.
BASIC-52 TEST:
8 LEDs connected to PORT1. The following code shifts the LED between LSB to MSB.
01 REM 8 LED SHIFT
02 REM SHIFT LEFT AND RIGHT
10 LED = 1
20 IF LED <= 80H THEN PORT1 = 0FFH.XOR.LED ELSE GOTO 1000
30 LED = LED * 2
40 FOR J = 0 TO 999 : NEXT J
50 GOTO 20
900 REM RIGHT SHIFT
1000 LED = 080H
1100 IF LED >= 1 THEN PORT1 = 0FFH.XOR.LED ELSE GOTO 10
1120 LED = LED/2
1130 FOR J = 0 TO 999 : NEXT J
1200 GOTO 1100
Another test is running ASCIIART
01 REM ASCII ART SOFT CPU
02 REM ASCII ART CYCLONE IV
03     XTAL=48000000
05     TIME=0 :  CLOCK 1
10     FOR Y=-12 TO 12
20     FOR X=-39 TO 39
30    CA=X*0.0458
40    CB=Y*0.08333
50    A=CA
60    B=CB
70    I=0
80    T=A*A-B*B+CA
90    B=2*A*B+CB
100   A=T
110    IF (A*A+B*B)>4 THEN  GOTO 150
120   I=I+1 :  IF I<=15 THEN  GOTO 80
130    PRINT " ",
140    GOTO 170
150    IF I>9 THEN I=I+7
160    PRINT CHR(48+I),
170    NEXT X
180    PRINT
190    NEXT Y
200    PRINT TIME
210    GOTO 10
220    END
I2C interface:
;----- Definitions -------------------------------------------------------
; === CH558T ===
SDA        bit    P1.6                    ;I2C serial data line.
SCL        bit    P1.7                    ;I2C serial clock line.
I2CSTART Sends a start condition to I2C bus.
I2CSTOP Sends a stop condition to I2C bus.
I2CPUT [byte] Sends a byte to the I2C bus.
After calling, acknowledgment (0/1) received from the receiving side is entered in status (18H)
I2CGET ([acknowledge]) [variable]
Reads a byte from I2C to a BASIC variable and
acknowledge (0/1) returned to the sender, ACK = 0, NACK = 1
I2C EEPROM Write program using BASIC-52
I2C-EEPROM WRITEテストプログラム
100    FOR J=0 TO 63
200    I2CSTART
300    I2CPUT 0A0H
400   SADR=J*16
410   SADRH=INT(SADR/256)
420   SADRL=SADR.AND.0FFH
500    I2CPUT SADRH
600    I2CPUT SADRL
700    FOR I=0 TO 15
800   WD=SADR+I
810   WD=WD.AND.0FFH
900    I2CPUT WD
1000   NEXT I
1100   I2CSTOP
1200   FOR I=0 TO 200 :  NEXT I
1300   NEXT J
I2C EEPROM read program using BASIC-52
I2C-EEPROM READテストプログラム
100    FOR J=0 TO 63
200    I2CSTART
300    I2CPUT 0A0H
400   SADR=J*16
500    I2CPUT SADRH
600    I2CPUT SADRL
700    I2CSTART
710    I2CPUT 0A1H
800    FOR I=0 TO 15
810    IF I=15 THEN ACK=1 ELSE ACK=0
900    I2CGET (ACK)RD
910    PRINT RD,
920    NEXT I
930    PRINT
1100   I2CSTOP
1300   NEXT J
SPI interface:
SCS    BIT    P1.4    ; CH552/CH558 CS(SS)
MOSI    BIT    P1.5    ; CH552/CH558
MISO    BIT    P1.6    ; CH552/CH558
SCK    BIT     P1.7    ; CH552/CH558
SPISTART [speed] setup SPI interface - "speed" is system-clock division facter, must be 32 or above
SPIPUT [byte] put "byte" to SPI
** byte received from SPI are stored at address 18h of i-ram, same features as SPIROT
SPIGET [variable] get "valiable" from SPI
SPIROT ([byte]) [variable] data rotate, put "byte" and get "valiable" to/from SPI
SPICS [0/1] CS(SS) port Low/High control
MCP3002 – 10 Bit Analog to Digital Converter program using BASIC-52
100 REM MCP3002 – 10 Bit Analog to Digital Converter Test Program
200 REM
300 HIGH = 1
400 LOW = 0
500 SPICS  HIGH
600
700 DIM CMD(2), RESP(2)
800 CMD(0) = 68h
900 CMD(1) = 00h
1000
1100 SPISTART 96 : REM Clock 500KHz
1200
1300 For I = 0 To 100
1400   SPICS LOW
1500   SPIROT (CMD(0)) RESP(0)
1600   SPIROT (CMD(1)) RESP(1)
1700   SPICS HIGH
1800   AD =  RESP(0) * 256 + RESP(1)
1900   AD = AD .and. 03FFh
2000   V = AD * 5.0 / 1023
2100   PRINT AD, V
2200   FOR K=1 TO 10000 :  NEXT K
2300 NEXT I
2400
2500 END
SPI-EEPROM 25LC040A test program
100 REM SPI-EEPROM 25LC040A Test Program
200 REM
300 HIGH = 1
400 LOW = 0
500 SPICS  HIGH
700 Rcmd = 03h
800 Wcmd = 02h
900 Wecmd = 06h
1100 SPISTART 32
1300 J = 10
1500 REM EEPROM WRITE
1600 REM
1700 For Iw = 0 To 511 Step 16
1900   SPICS  LOW
2000   SPIPUT Wecmd
2100   SPICS  HIGH
2300   Iwh = int(Iw/256)
2400   Iwh = Iwh * 8
2500   Iwh = Wcmd .or. Iwh
2600   Iwl = Iw .and. 00FFh
2800   SPICS  LOW
2900   SPIPUT Iwh
3000   SPIPUT Iwl
3200   For I = 0 To 15
3300     J = J .and. 00FFh
3400     SPIPUT J
3500     J = J + 1
3600   Next I
3800   SPICS  HIGH
3910 REM WAIT FOR WRITE PROCESS END
3920 REM
3930 FOR I=1 to 100 : NEXT I
4000 Next Iw
4200 REM EEPROM READ
4300 REM
4400 For Iw = 0 To 511 Step 16
4600   Iwh = int(Iw/256)
4700   Iwh = Iwh * 8
4800   Iwh = Rcmd .or. Iwh
4900   Iwl = Iw .and. 00FFh
5100   Ph1. Iw,
5200   PRINT ":",
5400   SPICS  LOW
5500   SPIPUT Iwh
5600   SPIPUT Iwl
5800   FOR I = 0 TO 15
5900     SPIGET J
6000     Ph0. J,
6100   NEXT I
6300   SPICS  HIGH
6500   PRINT
6700 next Iw
6900 End
ADC:
ADCSTART [channel] setup ADC function - "channel" is aanalog input port number [0-7]
ADCGET [variable] get "valiable" from ADC [0-2047]
ADCSTOP close ADC function and analog port
ADC test program
10     REM analog port 4
20     ADCSTART 4
30     FOR I=1 TO 10
40     FOR J=1 TO 5
50     ADCGET ADV
60    V=ADV*3.3/2048
70     PRINT V,
80     FOR K=1 TO 4000 :  NEXT K
90     NEXT J
100    PRINT
110    NEXT I
120    ADCSTOP
BLUETOOTH MODULE:
We can change the Module default name to any other valid names mentioned in the AT command manual of the Bluetooth manufacturer. In this case the name is changed to BASIC-52. Most of the Bluetooth module comes with default baud rate of 9600. In this case the baud rate is changed to 19200.
CAUTION:
There is no capacitor used in SSOP20 adapter board or external decoupling or bulk capacitor for testing. It is recommended to add decoupling or bulk capacitor as per requirement.
To program the internal FLASH memory of CH558T, the IC needs to enter into bootloader mode. In this situation we need VDD33 pin #20 should have some minimal capacitor. Similary VIN5 pin#19 also should have few microfarad capacitor for reliable operation during flashing the internal FLASH. After that since we are not using the USB and only using Tx and Rx, those capacitors are unnecessary.
The following video shows the connection, connectivity with PC and running ASCIIART program which is standard benchmark for speed comparision. With CH558T at 48 MHz it took 11.92 seconds.
CH558T Single Chip Computer running BASIC-52 at 48 MHz with 4kB xRAM
For Bluetooth module programming using AT commands, please refer to the manufacturer datasheet. There are much  information available from my other project using CH552T.
The only difference is it runs at 48MHz and having internal xRAM of 4kB.
