RTL lib 1.0 Release
A project log for Play FPGA like Arduino
Build cool things with M10. For starters, you can build a Lego Monster Truck with it. For more fun, how about home automation through DTMF?
changyi-guChangyi Gu 03/31/2017 at 07:480 Comments
RTL lib 1.0 is released on GitHub, with the following peripherals:
*) ADC: ADC for Altera MAX10
*) BCD: Binary Codec Decimal
*) block_memory: BRAM inferred
*) chip_ID: chip ID for Altera MAX 10
*) codec: voice codec
*) debug_counter_led: counter and led for debug
*) FASM_register: register for Wishbone FASM
*) flash_loader: module to load image into CFM
*) interrupt: interrupt controller
*) SD: MicroSD card controller
*) SRAM: Serial SRAM
*) SRT_DIV: radix 4 SRT division
*) switch_debouncer: button debouncer
*) timer: 8051 timer
*) UART: Async Serial port for 8051
