Modeling and simulation
A project log for IoT Mechanical Watch Winder
To solve the age-old first-world-problem of having too many automatic mechanical watches, configurable from a smartphone!
solenoidSolenoid • 03/25/2017 at 12:01•0 Comments
I designed this project using SolidWorks, it has some fun tools (non-intuitive as they can be sometimes...) like motion study. It allows to show how the device moves/performs when the motor turns, if the mating between the parts is done properly all connected elements follow the driving motor.
I added a rotational motor to the axis of the stepper motor and after fiddling with the settings for a while I got this mesmerizing moving mechanical watch winder:
I used small bits of PLA filament to connect the rings so that they can rotate relative to each other. On the prototype I used a soldering iron to melt the filament pieces inside the rings, otherwise they would've fallen out, but it looked really ugly. I realized that the rings can be deformed enough so I can insert the filament piece without having to leave the side of the rings open.
It turns out the side supports were unnecessary as the front and back supports for the big ring held it well enough.
Finally, instead of using pieces of filament and glue to connect the big ring to the supports and the small ring to the "inner support" I decided to use screws to avoid glue.
