5x7 RGB LED display using 2020 surface mount rgb addressable leds with the Arduino ATtiny microcontroller, chain-able on I2C control.
Using the jtap updi programming pin, and using the Nano as the programmer, we upload display programs to the ATtiny1604 microcontroller that controls the seven data lines, each with five rbg leds in series. When using the Nano to control the display unit with the I2C lines, we must remember to use 10k pull-up resistors on the SDA an SCL signal lines. But the onboard ATtiny1604 is capable by itself, to be master of many slaves.
Below is a test program for four rgb 5x7 led display modules on the I2C bus:
Here is a schematic of a typical application using the display modules with a USB to TTL converter for communication with the computer on any type of terminal emulation program for control of the rgb 5x7 matrix display modules. If these are too small to see, hit the 'view gallery', at the top left under the pictures.
mostly VCC and GND for the RGB leds. I use DOS ORCAD to make 4 layer pcb, sent gerbers to JLCPCB. Sometimes I use RUSH pcb or ADVANCED pcb. Going to try selling on Tindie maybe.
Aaaaw yiss, tinys for the win! Love this kind of stuff.
What are the vias on the bottom used for? Are they gnd-Connections? Otherwise you could use SMD-pins and move everithing below the LED´s to make it a cleaner appearence.
Don't want to spill the beans too much, but the radio badge would have a bunch of rgb leds on it, have a socket for a 'C6' esp module on it, with a 3.7 volt recharable battery system. To be worn at tech conventions, to direct attendees, sort of a wireless business card. So I have a lot to learn at legal zoom. This would have many, many other capabilities.
