Testing ALU
A project log for BX-8
Homebrew 8-bit TTL CPU, generation 2 of an ongoing series toward running Linux.
bohan-xuBohan Xu 03/13/2026 at 21:410 Comments
So the ALUI doesn't exactly work. I took the FPGA I was using and put it into a testing circuit. I'm testing it and it doesn't work. Trying to fix it hopefully I will find a solution sometime soon! If you have anything to say please comment! Thanks! Here's a picture:
