In order to get a proper System Design Document out I also had to sum up all the used libraries including their license information, open source software and what-so-open-ever else to pay appropriate appreciation to all those great projects out there. Reading this makes me feel like I actually did totally nothing in this project.
Credits and Licensing
The Hoverlay II hardware, CAD, and all application code is licensed under GPL V3 http://www.gnu.org/licenses/gpl.html
This project would not have been possible without open source hard- and software. Special thanks the following open source projects, that have been used in making and/or are part of Hoverlay II:
Hardware Design:
- OpenScad http://www.openscad.org (GPL V2)
- Processing http://www.processing.org (GPL V2, LGPL, GPL)
Manufacturing:
- RepRap Project http://www.reprap.org (GPL)
- Repetier http://www.repetier.com (Apache License V2)
- Slic3r http://www.slic3r.org (Perl Artistic License & AGPLv3)
- LinuxCNC http://linuxcnc.org (GNU GPL)
Application Development:
- Processing http://processing.org (GPL V2, LGPL, GPL)
- KinectA http://kinecta.mihoo.de (GPL V3)
- OpenNI https://github.com/OpenNI/OpenNI (Apache License V2)
- MSAFluid Processing library https://github.com/memo/p5-MSAFluid (MIT License)
- oscP5 Processing library http://www.sojamo.de/libraries/oscP5/ (GNU LGPL V2.1)
- Minim Processing library http://code.compartmental.net/tools/minim/ (GNU LGPL)
- saitoobjloader Processing library https://code.google.com/p/saitoobjloader/ (MIT License)
- Arduino http://arduino.cc (Creative Commons ShareAlike)
Also thanks to Christian Knüll for his efforts in making an affordable CAM tool
available. Check it out at http://estlcam.de (not open source!)
All layouts have been made with Adobe Illustrator (also not open source!).
Of course the used Microsoft Kinect is not open hardware. If you want to learn more about how the Microsoft Kinect is licensed, read the manual from page 14 here: http://download.microsoft.com/download/f/6/6/f6636beb-a352-48ee-86a3-abd9c0d4492a/kinectmanual.pdf
And last but not least, without the support of my local makerspace "Attraktor", not a single prototype would have been realized. If you live in or nearby Hamburg, Germany, you should definitely give us a visit sometime!
Moritz Walter
