LimeSDR test: Limesuite was used to 'scoop up' settings generated by Pothos
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
goat-industriesGOAT INDUSTRIES 04/16/2017 at 16:270 Comments
I used Pothos to create a block diagram for the LimeSDR that receives a local FM station and re-transmits it 1Mhz higher at very low power.
Limesuite was then used to 'scoop up' the settings generated by Pothos with the idea of closing Pothos and recreating the whole test using Limesuite alone.
The whole test worked nicely!
I then tried a similar thing in the LTE band 20 at 809 MHz, just repeating the whole base station Tx spectrum, using my trusted USD020 duplexers ..... And that worked too! I've been trying to do this for about 5 days, so why does it suddenly work now? I think the answer is that the Limesuite needs to be a 'blank canvas' before trying to scoop from Pothos, otherwise settings 'left over' from previous trials mess things up.
Files used:
https://cdn.hackaday.io/files/20500877072000/Simple_806MHz_Repeat 01.ini
https://cdn.hackaday.io/files/20500877072000/Simple 806MHz repeat 01.pothos
https://cdn.hackaday.io/files/20500877072000/FM retransmit 04.ini
https://cdn.hackaday.io/files/20500877072000/FM Re-Transmit 04.pothos
