Testing Limesuite calibration widgets using FM re-transmit
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
goat-industriesGOAT INDUSTRIES 05/24/2017 at 18:480 Comments
Whilst waiting for my analogue VGA PCBs to arrive from Shenzeng I thought I'd have a go at the next logical step in trying to get the LimeSDR to work as a Femtocell.
There's a lot of talk on the Lime Microsystems Myriad forum about calibration which got me thinking about why this gadget won't boost the band 20 4G signal when my DIY analogue circuits are now working and whilst the following video is not the most entertaining to watch, it does show that calibration settings can be adjusted manually.
The workflow is as follows:
  1. Load up blocks into Pothos to build a simple FM receiver,
  2. tune it to my local radio station,
  3. load in blocks to transmit it to another frequency 1MHz higher,
  4. run the program in Pothos,
  5. stop the program,
  6. connect LimeSDR in Limesuite,
  7. change a couple of settings in the Limesuite tab to enable transmit once more,
  8. check there's a response on my second computer,
  9. fiddle about with the various calibration widgets in Limesuite, listening for audio improvement / degradation.
Best watch the video really!
