Design Evolution
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
Tegwyn☠TwmffatTegwyn☠Twmffat 07/25/2017 at 19:080 Comments
As time goes on, the plan is evolving and slowly things fall into the right place. The next phase of the project will be to add a Base Rx signal path:
