Learning the LimeSDR Tranciever.
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 04/04/2017 at 09:320 Comments
Whilst waiting for new antenna cables to arrive, I'll be programming this LimeSDR transceiver to pick up an FM radio station as a learning exercise. I did try using this device as a Femtocell but failed due to the incredible complexity of this gadget and my incredible lack of expertise! There are plans afoot to connect the SDR to an Arduino and carry on learning how to use it properly.
