Not sure what's going on here. Adjusting one channel seems to affect the other channel and I wouldn't expect that to happen! If anybody can check this out, the file is in the files section: Testing MIMO 01.pothos.
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
