At last a promising .ini file for the LimeSDR!
A project log for Cell Phone 4G LTE Repeater / Booster / Femtocell
An outside pole mounted aerial picks up 4G signals which are then filtered, amplified and re-transmitted through a second inside aerial.
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 04/18/2017 at 12:410 Comments
Thanks to Zack (again!) at Lime Microsystems, I seem to have managed to produce a functioning repeater in full duplex mode. It does not actually help with 4g on my own phone yet as it probably needs some fine tuning.
Here's the file:
https://cdn.hackaday.io/files/20500877072000/Band_20_Repeater_01.ini
