Three-Chamber Rotary-Valve Pulsed Combustion Demon
Three-chamber pulsed combustion demonstrator using a rotary valve and Hall sensors to mechanically sequence ignition and fuel.
0 followers
This project explores a bench-scale, three-chamber pulsed combustion demonstrator that uses mechanical phase-locking instead of software timing or fast solenoid valves. Three identical steel chambers are arranged radially and fed sequentially from a common rail using a rotary aluminium disc valve. Ignition is indexed directly from valve position using Hall sensors, so fuel admission and ignition are physically tied to rotor phase rather than firmware. Each chamber exhausts independently to reduce pressure coupling and flashback paths. The system is intended as an experimental platform, not a propulsion device, and is operated at low repetition rates suitable for controlled bench testing. Early validation relies primarily on video and audio evidence to study sequencing order, repeatability, misfires, and isolation before adding instrumentation. The focus is on clarity and observability—understanding how simple multi-chamber pulsed combustion sequencing can be made without complex el
HHO is a dangerous explosive gas do not try to use any of the information supplied.
Descriptionin PDF Below.
My main concern at present is sealing the rotary disc gas transfer and the quantity of HHO that will get into the combustion Chambers.
any helpful contributions welcomed
Description Paper.pdf
Adobe Portable Document Format - 74.74 kB - 02/09/2026 at 23:30
Preview
  • Alloy drilling and planetary direct drive
    Graeme02/09/2026 at 23:49 0 comments
    I am in the process of using the lathe to get flat surfaces, then pilot drill all holes and fabricate a hole saw  type tool to cut the oring grooves in the alloy.
    I have made a 3d Printed planetary Direct drive motor holder  with D drive for thr rotor shaft.
View project log
