A compact receiver requires a simple but consistent user interface.
All parameters are updated immediately when adjusted, eliminating the need for an explicit ‘apply’ operation.
Frequency tuning resolution is defined by a dedicated step mode.
EEPROM storage is used only to restore parameters after power cycling.
The interface separates real-time control from persistence, keeping operation simple while maintaining flexibility.
1. Control Interface
Input device: Rotary Encoder
Actions:Rotate/Push/Double Push
2. Global Behavior
All parameters are updated immediately when changed (live behavior)
No explicit “apply” or “confirm” operation exists
Parameter values are always active once adjusted
Store current parameters to EEPROM for restoration after power cycling
3. Mode Switching Behavior
Push→ Switch to Select Mode
Double Push→ Store current parameters to EEPROM
→ Parameters are restored after power cycle
→ When MEM mode, store the frequency in the MEM channel
→ When SCN mode, going into Automatic scan mode
4. Mode List
FREQ : Frequency
STEP : Frequency Step
MEM : Memory Channel
SCN : Scan Channel
VOL : Volume
SQU : Squelch Level
BAND : AM (air band) / FM
B_W : AM band width
F_COR : Crystal Frequency Calibration
ACA : Automatic scan mode
5. Mode Specifications
FREQ Mode
Parameter : Receiving frequency
Range : 118 – 136 MHz (AM) / 76 - 109 MHz (FM)
Resolution: Defined by STEP mode
Behavior : Changes immediately (live)
STEP Mode
Parameter : Frequency step size
Options : 10Hz / 1kHz / 10kHz / 100kHz / 1MHz / 25 kHz
Behavior : Defines increment/decrement step in FREQ mode
VOL Mode
Parameter : Audio volume
Range : 0 - 63
Behavior : Immediate effect on audio output
SQL Mode
Parameter : Squelch threshold
Range : 0 - 63
Behavior : Audio muted below threshold level
MEM Mode
Parameter : Memory channel
Range : CH0 – CH49
Behavior : Select memory channel number / assign current frequency
SCN Mode
Behavior : Assign memory channel frequency
BAND Mode
Parameter : AM (air band 118 - 136 MHz) / FM (76 - 109MHz)
B_W Mode
Parameter : Si4732 AM band width
Unit : 0 - 6 (0:6kHz,1:4kHz, 2:3kHz, 3:2kHz, 4:1kHz, 5:1.8kHz, 6:2.5kHz)
F_COR Mode
Parameter : Crystal frequency correction
Unit : Frequency offset (±Hz for 25MHz of Si5351a)
Behavior : Adjusts local oscillator accuracy
6. Frequency Control Rule
Frequency increment/decrement is quantized by STEP setting
Changing STEP immediately affects FREQ tuning resolution
7. Persistence Behavior
EEPROM stores:
Current parameters (mode-dependent)
Stored values are:→ Restored automatically at power-on
Automatic scanning
Double Push on SCN mode → Automatic scanning mode
Sweep MEM channels every 200mS, if there is signal, stay 1 Sec more.
Signal detection (squelch open / RSSI threshold)
nobcha
