Update: What I learned about the front end filter instead of 2 stages stagger resonator after assembling the PCB circuit.
A project log for I Built an Airband Receiver Around a $1 Radio IC
What happens when you combine the RF section of a cheap portable radio with a modern DSP receiver chip? TA2003&Si4732.
nobchanobcha 06/30/2026 at 12:500 Comments
The front-end filter of this receiver originally used a two-stage staggered configuration, but I switched to a three-stage Chebyshev design to improve the skirt characteristics. This resulted in better attenuation performance in the FM broadcast band and the upper image frequency range.
https://nobcha23.hatenadiary.com/entry/2024/08/22/185607
