Plastic bottle crashing speed breaker
A speed breaker used as a plastic bottle crasher that uses weight of the passing car instead of powered motor or compressor to crush bottles
A speed breaker that can be used as a plastic bottle crasher that uses weight of the car instead of powered motor or compressor to compress the plastic bottle. It works by combining - A structural ramp plate and rollers that a vehicle drives over - Crushing surfaces or channels sized for bottles - Mechanical advantage (levers, cams, inclined planes) so downward wheel load compresses the plastic Advantages - No electricity, motors or compressors - Very low maintenance (fewer moving parts) - Can be integrated into traffic calming infrastructure Because of the rotating rollers due to shear force, rollers guides the movement of crashed bottles from the first trash bin where the bottles are disposed to the other side where they will be collected again in another bin. The spring systems and the hinges play the up and down movement of the crushing plates. The system happens to restrict wrong lane traffic because the structure only allows left side for forward travel
Plastic waste particularly single use plastic bottles has become one of the most visible and persistent environmental problems in urban areas. Many cities struggle with collecting and processing these bottles because they occupy large volumes in waste bins and transportation trucks. This project proposes an innovative mechanical infrastructure solution that combines a traffic speed breaker with a passive plastic bottle crushing system. The device uses the weight of passing vehicles to compress plastic bottles without requiring electricity, motors, or external power sources.
The proposed system is installed across a roadway in a similar manner to a conventional speed bump. It consists of a reinforced upper crushing plate connected to a hinge mechanism on one side and supported by a return spring system. Beneath the plate lies a closed loop structural frame containing a crushing chamber and a rotating roller that guides crushed bottles toward a secondary collection bin. The entire structure is embedded in the road surface and designed to withstand repeated vehicle loads.
The operation of the system is simple and automatic. Plastic bottles are deposited by users into an intake bin located at one side of the structure. From the bin bottles move into a horizontal crushing channel positioned beneath the hinged upper plate. When a vehicle drives over the speed breaker the wheel applies downward force to the plate. This force causes the plate to pivot around the hinge compressing the bottles against the lower crushing surface. The compression flattens the bottles and significantly reduces their volume.
During the crushing process the bottles come into contact with a cylindrical roller located within the chamber. Due to the shear force created by the downward motion of the plate and the movement of the bottle material the roller rotates. This rotating action helps guide the crushed bottles toward the opposite side of the system. The crushed bottles are then collected in a second storage bin where they can later be removed for recycling.
After the vehicle passes over the device the return springs expand and lift the crushing plate back to its original position. This resets the mechanism and prepares it for the next cycle of operation. Because the system relies solely on the mechanical energy generated by vehicle weight it can operate continuously without electricity, sensors or electronic components. This makes the design especially suitable for areas with limited infrastructure or unreliable power supply.
An additional feature of the design is its ability to discourage wrong direction traffic. The speed breaker structure can be shaped asymmetrically so that it provides smooth passage for vehicles traveling in the correct direction while creating resistance for vehicles attempting to drive in the opposite direction. This adds a traffic control benefit alongside its environmental function.
By compressing plastic bottles at the point of disposal the system significantly reduces the volume of collected waste allowing more bottles to be stored and transported efficiently. This can lower waste collection costs, reduce landfill usage, and encourage recycling practices in busy public areas such as parking lots, shopping centers, campuses, and roadways.
Overall, the passive vehicle powered bottle crushing speed breaker represents a sustainable, low-maintenance, and energy-free solution for managing plastic bottle waste while simultaneously serving as a traffic calming device.
I asked AI if it is original idea and it didn't disappoint me.
Integrating a vehicle activated bottle crusher into urban speed breakers can realistically achieve up to approximately 70–80% volume reduction of empty PET bottles when proper venting and compression geometry are incorporated. This substantial compaction at the point of disposal directly supports sustainable city objectives by decreasing waste storage requirements, reducing collection frequency and lowering transportation...
  • 3D drawings
    Anteneh Gashaw03/14/2026 at 15:17 0 comments
    The following 3D drawing shows the design of core mechanism of the system. The design have very few parts for ensuring reliability, low cost and low maintenance. Because of the rotating rollers due to shear force, rollers guides the movement of crashed bottles from the first trash bin where the bottles are disposed to the other side where they will be collected again in another bin. The spring systems and the hinges play the up and down movement of the crushing plates. The system happens to restrict wrong lane traffic because the structure only allows left side side for forward travel.
View project log
Merlin wrote 03/18/2026 at 11:01 point
Many technological 'solutions' don't solve anything but only add complexity to an already overly complicated world. In my opinion this is another example how to complicate life: making a complex "solution" for a apparent problem that should not exist in the first place: Too many plastic bottles.
Education and incentives to use less plastic in general are money/energy better spent.
This comment besides others that mention energy usage, jamming, vandalism, abuse  etc.
Anteneh Gashaw wrote 03/18/2026 at 12:01 point
I agree that reducing plastic at the source is important but current alternatives can’t meet global demand and widespread adoption would take decades even if they do... and this is another big topic for discussions which many industrialists vs environmentalists are arguing over
This passive energy free system handles existing bottles efficiently, crushing and guiding them to collection bins as a low cost, low maintenance proof of concept to complement broader waste reduction efforts... thanks for the follow up
Ken Yap wrote 03/14/2026 at 22:27 point
A real, functional RVM (reverse vending machine) like the ones here requires electricity to run the barcode scanner to admit only eligible bottles (plastic and glass) and cans, and power the computer issuing the refund vouchers. Some keen scavengers return hundreds of bottles and cans at a time for tens of dollars refund, making your small collection bin risible. And inevitably your design will jam sometime because IRL not all returns are in pristine shape as depicted which means a person will have to clear it, and in proximity to traffic.
Then in the energy equation you have to account for the trucks taking away the huge number of bottles and cans accumulated. But it's worth it to keep plastics out of the environment and recover the metal and glass which needed a lot of energy to create from raw material. These days there is plenty of solar power in the grid to power the RVM and some day the truck will be electric.
If you want to recover energy from the speed hump, you're better off feeding it back to the grid, assuming the small amount is worth the capital cost.
You've probably used more energy on AI than you'll ever get out of this impractical idea.
Anteneh Gashaw wrote 03/14/2026 at 22:43 point
@Ken Yap Thank you for the thoughtful feedback. I agree that reverse vending machines are effective where deposit systems exist especially for sorting and refunding bottles. My concept is not intended to replace those systems. Instead it explores a different approach which is a passive mechanical infrastructure that can operate without electricity or user interaction.
The idea is aimed at environments where reverse vending machines are not practical due to cost, power availability or maintenance requirements. In many places plastic bottles are discarded in public areas or roadsides rather than returned for deposit. A passive system integrated into traffic calming infrastructure could help reduce volume and collect waste opportunistically.
You raise good points about maintenance and jamming. In a real implementation the crushing channel would need self clearing geometry, access panels for safe maintenance and larger collection bins connected to periodic waste collection. These are engineering challenges but not fundamentally different from those addressed in other mechanical waste systems.
Regarding energy recovery the goal of the concept is not to generate electricity but to use the unavoidable mechanical energy of vehicles already slowing down at speed humps to perform useful work namely volume reduction of plastic waste.
I appreciate the critique and the opportunity to think through these practical considerations. Feedback like this helps improve the design.
Ken Yap wrote 03/14/2026 at 22:53 point
Experience has shown that a Container Deposit Refund is the most effective way to get people to take them to a central collection point where the operation can be done efficiently. People even go collecting containers for the refund, cleaning the environment. Your machine has no such incentive and will get vandalised in no time.
BTW there's no need to both reply and use a @ tag, it just generates more notification noise.
Anteneh Gashaw wrote 03/14/2026 at 23:03 point
@Ken Yap You’re absolutely right that container deposit systems are very effective where they exist. They create a strong incentive for people to return bottles and the centralized processing makes sorting and recycling efficient.
My concept isn’t meant to replace those systems. It’s more about addressing a different situation which is for places where deposit programs aren’t implemented or where bottles still end up in public spaces, roadsides or general waste streams. In many cities around the world plastic bottles are simply discarded rather than returned.
The idea here is to explore whether existing infrastructure (like traffic calming devices) could be used to passively reduce the volume of bottles and collect them without requiring electricity, user interaction, or behavioral incentives. It’s more of a complementary concept than an alternative to deposit systems.
You’re also right that vandalism and maintenance are real concerns for any public device. Those are important engineering considerations that would need to be addressed with robust construction, protected access panels and appropriate placement.
I appreciate the perspective and it’s helpful to think about how different approaches to recycling infrastructure can coexist depending on the context.
anime_penpal wrote 03/10/2026 at 17:44 point
AI Slop. "no electricity"... then how do you get the bottles into slots and back out? Who moves them?
This kind of garbage should be banned.
Anteneh Gashaw wrote 03/14/2026 at 15:30 point
Because of the rotating rollers due to shear force, rollers guides the movement of crashed bottles from the first trash bin where the bottles are disposed to the other side where they will be collected again in another bin without electricity.
AI is great tool to use to visualize a description. Feel free to see the CAD model of the core mechanism
Thank you for your comments and feel free to follow the project development
Sushionroad wrote 03/06/2026 at 18:52 point
This has to be meant as a joke
Anteneh Gashaw wrote 03/14/2026 at 22:51 point
@Sushionroad  April Fool’s isn’t until next month 🙂 The concept is meant seriously though. It explores whether traffic infrastructure could passively compress plastic waste using vehicle weight instead of powered machinery. It’s still an early concept but I’m interested in taking it to market when the time is right
burner wrote 02/28/2026 at 12:49 point
I had to check calendar. You are month too early?
