DIY UPS for Home Assistant Green & Xfinity XB7 Mod
DIY 12V LiFePO4 UPS for Home Assistant Green and Xfinity XB7 modem. Victron BP-65 LVD, MOSFET ideal diode, 13.3V float, Shelly Plus Uni
System Overview AC grid powers a Mean Well HDR-60-12 PSU set to 13.3V float, which charges a 12V 10Ah LiFePO4 battery through a MOSFET ideal diode. On grid failure, loads switch directly to battery in under 1ms. A Victron BatteryProtect BP-65 disconnects loads at 11.8V to prevent over-discharge. A Shelly Plus Uni reports battery voltage and temperature to Home Assistant.
DIY UPS for Home Assistant Green & Xfinity XB7 Modem
A 12V LiFePO4-based uninterruptible power supply for keeping a Home Assistant Green and Xfinity XB7 cable modem running during grid outages. Built into an IP65 enclosure with Home Assistant monitoring via Shelly Plus Uni.
Honest context: A $85 APC BE600M1 provides comparable backup capability. This build costs roughly the same over 10 years as that option (based on battery replacements and electricity usage). The engineering rationale — longer battery life, faster switchover, direct HA integration, no DC-DC converter voltage regulation — is documented in design-rationale.md. Build this if those tradeoffs matter to you.
Project Update: Transitioning to UPS-MONITOR-V2
To further optimize the reliability and data granularity of the system, I am moving toward the implementation of UPS-MONITOR-V2: a bespoke 20-bit power monitoring solution designed to replace the generic Shelly Plus Uni. Built around the Texas Instruments INA228 and ESP32-C3, this custom PCB provides high-precision tracking of voltage, current, and hardware-level energy accumulation with a negligible ~243mW footprint—a 50% power reduction over the previous implementation. Featuring true Kelvin-sensed 4-terminal current measurement and a high-efficiency synchronous buck regulator, the board delivers zero-blind-spot monitoring directly into Home Assistant via ESPHome, ensuring every milliamp-hour of the 10Ah LiFePO4 cell is accounted for during grid outages.
Performance
Summary Validated Runtime: 4.25 hours to software shutdown (12.2V) and ~4.3 hours to hardware LVD (11.8V) under a sustained 14.5W load.
Key Finding
The UPS delivers a reliable ~4.3 hours of runtime at typical Xfinity XB7 Modem and HA Green loads (~15w). This is ~55% of the theoretical maximum capacity of the 10Ah LiFePO4 battery. This result is not due to battery degradation, measurement error, or software issues. It is a direct consequence of the single-rail 13.3V CV architecture.
Why the Runtime is Limited
The system uses a single shared rail for both charging and load. To keep the voltage safe for the connected equipment, charging is capped at 13.3V. This restricts the battery to approximately 65–75% SOC and prevents proper absorption charging at 14.4V. As a result, the top ~25–35% of the battery’s rated capacity is never accessible.
Discharge Characteristics
Extremely flat voltage plateau from 13.0V down to 12.8V (delivers the majority of usable energy)
Sharp “cliff” begins at ~12.45V, after which voltage drops rapidly
12.4V warning provides an effective “immediate action” alert (~5–6 minutes before shutdown)
Conclusion
The system performs exactly as designed. The layered protection (voltage warnings → automated shutdown → BP-65 hardware LVD) is robust and safe.
Current validated specification: ~4.3 hours runtime at 14.5W under the existing single-rail topology.
A two-stage charging architecture (dedicated 14.4V charger + DC-DC regulator) would be required to approach the full ~7.8–8.5 hour theoretical runtime.
Complete Report and Data can be found at: https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/UPS_Validation_Report.md
Last validated: March 2026 (Test D3)
UPS Integration into Home Assistant
HA Integration details can be found at: https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/HA%20Automation/README_HA_UPS_Integration.md
Commissioning Results
The chart records a full two-cycle discharge test performed March 25–26, 2026 using a Netgear R6400 router (~7W DC) as a substitute load, with battery voltage logged via the Shelly Plus Uni at 5-second intervals. Discharge 1 (7.76h): Voltage held the characteristic LiFePO4 flat plateau from 13.2V to...
UPS_Final_Report.pdf
Commissioning Run
Adobe Portable Document Format - 40.93 kB - 03/26/2026 at 23:39
Preview
System Architecture
Portable Network Graphics (PNG) - 43.27 kB - 03/06/2026 at 13:25
Preview
  • 1 × Mean Well HDR-60-12 PSU
  • 1 × Cyclenbatt 12V 10Ah LiFePO4 Battery
  • 1 × Victron BatteryProtect BP-65 12/24V
  • 1 × Pololu Ideal Diode 4-60V 10A
  • 1 × Shelly Plus Uni
View all 14 components
View all 2 project logs
  • 1
    Wiring Instructions
    Wiring Reference
    All wiring is 16AWG. See voltage-drop-analysis.md for resistance and drop calculations.
    Fuse Locations and Ratings
    FuseRatingLocationPurpose
    F110A fast-blowPSU outputProtects PSU output circuit
    F210A fast-blowBattery positiveINSTALL FIRST — protects battery circuit
    F32A fast-blowBP-65 OUT → HA GreenProtects HA Green load circuit
    F45A fast-blowBP-65 OUT → XB7 ModemProtects Xfinity Modem load circuit
    Install F2 before connecting the battery to any other part of the circuit. This is the primary short-circuit protection for the battery.
    Component Mounting
    ComponentMounting Method
    Mean Well HDR-60-12 PSUVelcro to enclosure base, stabilize to wall
    Victron BatteryProtect BP-65Velcro to enclosure base
    Pololu Ideal DiodeFloat — secure with wire ties
    Shelly Plus UniFloat — secure with wire ties
    Lever NutsFloat — secure with wire ties
    WiringCable clips as needed for strain relief
    Wiring Connections — From/To Reference
    AC Input → PSU
    FromToNotes
    Power Cord — Black (Hot)PSU Pin 1 AC/L
    Power Cord — White (Neutral)PSU Pin 2 AC/N
    Power Cord — Green (Ground)N/Agreen ground is cut back, capped with a wire nut, and taped, because the HDR-60-12 is a Class II double-insulated
    PSU → Ideal Diode
    FromToNotes
    PSU Pin 4/5 DC Output V−Ideal Diode GND (V−)
    PSU Pin 6/7 DC Output V+Ideal Diode VIN (V+)Via F1 (10A)
    Ideal Diode → Terminal Block
    FromToNotes
    Ideal Diode GND (V−)Input 2 (−)Terminal Block has 2 inputs
    Ideal Diode VOUT (V+)Input 2 (+)Terminal Block has 2 inputs
    Battery → Terminal Block
    FromToNotes
    Battery (V−)Input 1 (−)Terminal Block has 2 inputs
    Battery (V+)Input 1 (+)Via F2 (10A)
    Terminal Block → Victron BatteryProtect BP-65
    FromToNotes
    Terminal Block +BP-65 IN terminal
    Terminal Block −BP-65 GND terminalUse included 1.5mm² wire
    Victron BP-65 OUT → Loads
    FromToNotes
    BP-65 OUT terminalF3 input (2A)HA Green load circuit
    F3 outputHA Green barrel plug (center +)5.5mm × 2.1mm, center-positive
    BP-65 OUT terminalF4 input (5A)Xfinity Modem load circuit
    F4 outputXB7 Modem barrel plug (center +)5.5mm × 2.1mm, center-positive
    Terminal Block −HA Green barrel plug (sleeve)Common return
    Terminal Block −XB7 Modem barrel plug (sleeve)Common return
    Shelly Plus Uni Monitoring
    FromToNotes
    Battery + (Terminal Block)Shelly Pin 1 (V+)Module power in (+)
    Battery − (Terminal Block)Shelly Pin 2 (GND)Module power in (−)
    Battery + (Terminal Block)Shelly Pin 3 (Analog In)Bridge to Pin 1 — battery voltage sense; primary shutdown trigger at 12.2V
    DS18B20 Yellow/White (Data)Shelly Pin 5 (Data)1-Wire temperature data
    DS18B20 Black (GND)Shelly Pin 6 (Sens. GND)Temperature sensor ground
    DS18B20 Red (VCC)Shelly Pin 7 (3.3V Out)Temperature sensor power
    Enclosure Layout
    See https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/assets/UPS_Layout_with_12_Volt_Regulator.png for the assembly drawing image.
    The enclosure is a LeMotech IP65 ABS junction box (9.6″×7.6″×4.5″ interior). Key layout decisions:
    • PSU occupies the left side; battery occupies the center. Physical separation provides AC/DC segregation and reduces EMI coupling.
    • Cable glands (1/2" NPT) on the bottom face: AC input on the left, DC output barrel jacks on the right.
    • Victron BP-65 mounts on the right side wall. Terminal block sits between battery and BP-65.
    • Shelly and ideal diode float above the battery, secured with wire ties.
    • All 16AWG runs are kept to approximately 6" segments to hold voltage drop 41mV at typical load and 63mV at peak.
View all instructions
Bill Collis wrote 03/01/2026 at 19:17 point
Hi Nicholas,
This is one of the nuances of the design -
Neither — this design bypasses CC-CV entirely by using passive float
  charging.
  How it works:
  - PSU is set to 13.3V (LiFePO4 resting voltage)
  - Current is naturally limited by the voltage differential between PSU and battery
  - As battery charges, the differential shrinks → current tapers organically
  - At equilibrium, current drops to near-zero (microamps)
  The BMS role:
  - The Cyclenbatt's built-in 10A BMS provides protection only (OVP, UVP, OCP, short circuit)
  - It does not regulate charging current — it would only intervene if current exceeded 10A (which can't happen here since max PSU output is 8.5A, and typical charge current is <2A)
  Why this works for LiFePO4:
  - LiFePO4 has a flat discharge curve and tolerates indefinite float at 13.3V
  - No risk of overcharge since 13.3V is below the 14.4-14.6V charge termination voltage
  - Trade-off: charges to ~95% SoC rather than 100%, but extends cycle life
Hope that answers you question.
Bill
PN Labs wrote 03/01/2026 at 18:57 point
Hi Bill,
Wondering if you can share any details about the BMS and if it enables CC-CV charging for the lithium battery (or limits the current flow to the maximum safe CC level)
Regards,
Nicholas
