Architecture Overview
APEX-16 is a 16-bit pipelined CPU designed from scratch in Digital, a logic circuit simulator. The core design focuses on instruction-level parallelism through a 6-stage pipeline that can process multiple instructions simultaneously.
Pipeline Design
The CPU uses a 6-stage in-order pipeline:
- Fetch —Retrieve the next instruction from memory using the program counter
- Decode — Break down the instruction into opcode, operands, and register targets
- Register Read — Load values from source registers
- Execute — ALU handles integer operations, FPU handles floating point operations
- Memory — Load/store operations to RAM; passes through for non-memory instructions
- Write Back — Write results back to destination registers
Register File
- 16-bit wide registers across the entire CPU
- 1 Accumulator register (A) — primary computation register
- ~8 General Purpose Registers (R1–R8) — flexible storage for operands and results
- RAM addressing registers — dedicated registers for memory access (planned)
Execution Units
Arithmetic Logic Unit (ALU)
- Logic operations: AND, OR, NAND, NOT, XOR
- Shift operations: Left shift, Right shift
- Comparison: Less than, Greater than, Equal
- Integer arithmetic: Addition, subtraction (via adders in Digital)
Floating Point Unit (FPU) — In Progress
- Floating point addition
- Floating point subtraction
- Float format: TBD (standard format planned)
Complex Math Unit (CMU) — Under Consideration
- Potential support for multiplication and division
- Role and implementation still being evaluated
Design Challenges & Solutions
Version 1 Issues (Scrapped)
- Pipeline stall logic became too complex
- Rigid structure with low flexibility
- Tightly coupled components made debugging extremely difficult
- Data hazards (read-after-write) hard to resolve
Version 2 Approach
- Simplified pipeline stages
- Cleaner modularity for easier debugging
- Focus on getting the core pipeline working before adding complexity
- Better separation of concerns between execution units
Known Technical Challenges
- Data Hazards — Managing read-after-write dependencies in the pipeline
- Control Hazards — Branch prediction and instruction flow control
- Stall & Forwarding Logic — Preventing pipeline stalls while maintaining correctness
- Memory Access Timing — Coordinating RAM access through the pipeline
Implementation Details
- Simulator: Digital (by hnemann) — uses built-in adders and logic primitives
- File Format: .dig circuit files
Future Goals
- Complete floating point arithmetic implementation
- Finalize and document the Instruction Set Architecture (ISA)
- Implement virtual memory support
- Write test programs and simulation benchmarks
- Develop a simple bootloader or OS kernel
Inspiration & Learning Sources
- Intel CPU Architecture: i386–Pentium — Core understanding of modern CPU design
- MIT OpenCourseWare Pipelining Lectures — Pipeline architecture theory
- NAND Game — Practical understanding of floating point logic implementation
Current Status
Active development — Version 2. Early stage, focusing on pipeline correctness and core functionality before adding advanced features.
Bohan Xu
slederer
AranweLTT
Jara
Szoftveres
