Laser CNC, you are making this good :)
A project log for Cubetto Clone
I would like to build a re-engineered Cubetto clone for my son.
konkavKonkav 03/25/2018 at 22:070 Comments
I count it success. The CNC cut plywood, sanded with 320 grit sandpaper (to remove traces of burning):
It looks nice. The living hinges are half success. Basically OK, but not enough lines. I have put them on 5mm from each other, and it looks like too much. I will try out the 3mm.
There are cracks, and I hope that with more lines it will bend fine. We'll see soon.
