🚀 Project Overview
This project turns the GP2Y0D80Z0F digital infrared sensor into a rapid proximity detector with visual feedback on a 16×2 I²C LCD and serial console. It reports whether an object is within ~10 cm in real time, making it ideal for obstacles, presence sensing, interactive installations, or basic automation.
Unlike analog distance modules, the GP2Y0D80Z0F outputs a simple HIGH/LOW signal that your Arduino can read directly — no ADC or conversion math needed.
🔌 What You’ll Need
Arduino Uno — brains of the project
GP2Y0D80Z0F IR proximity sensor — detects objects < ~10 cm
16×2 I²C LCD display — for live status
Breadboard & jumper wires
USB cable for power + programming
📍 How It Works
The GP2Y0D80Z0F Distance Sensor with Arduino Uno emits infrared light and detects reflections from nearby surfaces. When an object enters ~10 cm range, its output goes LOW. When nothing is close, it stays HIGH. Your Arduino reads this digital pin and updates the display + serial output accordingly.
Quick tip: The sensor’s binary output means it can’t measure exact distance — only object present or not present.
🔧 Wiring
GP2Y0D80Z0F → Arduino Uno
VIN → 5 V
GND → GND
OUT → Digital Pin 2
16×2 I²C LCD → Arduino Uno
SDA → A4
SCL → A5
VCC → 5 V
GND → GND
📦 Arduino Code
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
const int SENSOR_PIN = 2;
LiquidCrystal_I2C lcd(0x27, 16, 2);
void setup() { Serial.begin(9600); pinMode(SENSOR_PIN, INPUT);
lcd.begin(); lcd.backlight(); lcd.print("Proximity Sensor"); lcd.setCursor(0,1); lcd.print("Initializing..."); delay(2000); lcd.clear();
void loop() { int state = digitalRead(SENSOR_PIN); lcd.clear();
if (state == LOW) { lcd.print("Object Detected"); lcd.setCursor(0,1); lcd.print("Distance <10cm"); Serial.println("Object close <10cm"); } else { lcd.print("No Object"); lcd.setCursor(0,1); lcd.print("Distance >10cm"); Serial.println("No object in range"); } delay(200);
🛠 Tips & Enhancements
Debounce output: filter quick transitions to stabilize readings.
Interrupt-driven detection: use hardware interrupts for faster triggers.
Multiple sensors: expand to create detection zones.
Actuators: drive buzzers, relays, or LEDs for alerts.
Troubleshooting Tips
Nothing on the LCD? Try alternative LCD addresses (0x27 ↔ 0x3F).
Flashing or unstable text? Only redraw on state change, or increase the loop delay.
Sensor always reads one state? Check wiring, pull-ups, and reflectivity of the object.
Unresponsive Serial Monitor? Ensure baud rate is set to 9600.
Explore 500+ detailed Arduino projects with code and circuit diagrams on CircuitDigest to kickstart your next maker build.
ElectroScope Archive
hIOTron
Akshay Jain
