Project Overview
This DIY IoT project shows you how to turn an Arduino Uno R4 + DHT11 sensor into a smart environmental monitor that automatically sends email alerts when the temperature exceeds a threshold. It leverages built-in Wi-Fi and the CircuitDigest Cloud Email API to deliver timely notifications straight to your inbox.
What You’ll Build
A wireless temperature alert system that:
Reads temperature & humidity with a DHT11 sensor.
Connects to the internet over Wi-Fi.
Sends structured alert emails when thresholds are crossed.
Avoids repeated alerts for the same event.Required Hardware
| Component | Qty |
| Arduino Uno R4 | 1 |
| DHT11 Temp & Humidity Sensor | 1 |
| Breadboard | 1 |
| Jumper Wires | As needed |
The DHT sensor’s data pin goes to digital pin 2 with the internal pull-up resistor enabled, and 5V/GND power connects to the Arduino.
How It Works
Startup & Sensor Setup: The sketch initialises the DHT11 and connects the Arduino to your Wi-Fi network.
Continuous Monitoring: The Arduino reads temp/humidity at regular intervals.
Threshold Check: If the temperature goes above your defined limit, the code formats a JSON payload and sends it via HTTPS POST to the CircuitDigest Cloud email endpoint.
Email Alert: The cloud API takes care of delivering a formatted alert email to your address.
Event Control: To prevent spamming, the system blocks repeated emails until conditions return to normal.
Key Code Concepts (Simplified)
Libraries & Sensor Setup
#include <WiFiS3.h> #include <DHT.h> #define DHTPIN 2 #define DHTTYPE DHT11 DHT dht(DHTPIN, DHTTYPE);
Sets up Wi-Fi and DHT11 sensor support.
Network Credentials
const char* ssid = "yourSSID"; const char* password = "yourPassword"; const char* host = "www.circuitdigest.cloud"; const int port = 443;
Define your Wi-Fi and cloud API server details.
Temperature Logic
const float TEMP_THRESHOLD = 30.0; // trigger point
if (temperature > TEMP_THRESHOLD) { sendEmail(temperature, humidity);
When temp exceeds the threshold, trigger the email function.
Sending JSON Over HTTPS
The sendEmail() function builds a JSON body with current sensor values and sends it securely to the cloud API, which then handles final email delivery.
Troubleshooting Tips
Wi-Fi Fails: Check SSID/password and serial monitor status.
Sensor Returns NaN: Ensure correct wiring and stable connections.
No Email Received: Validate API key, template ID, and email destination. Check spam/junk folders.
Too Many Alerts: Ensure flags and timing logic prevent frequent repeats.
Where You Can Use It
Server room safety alerts
Home environment monitoring
Greenhouse climate control
Cold storage oversight
IoT learning platforms
This Arduino Send Email Notifications shows how simple sensor data can be elevated into a connected alert system using cloud services — perfect for real-world IoT applications and community showcases.
Explore 500+ Arduino Projects with code, circuits & step-by-step tutorials at CircuitDigest to spark your next DIY electronics idea.
ElectroScope Archive
bhaskar.anil430
muzi
Mr. Sarful hassan
Arduino KIT
