Building a high-quality sound card from scratch
Design of a High-Performance Sound Card Based on PCM1792, SRC4193, and TPA6120
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This project documents the design and construction of a high-quality sound card featuring USB and optical (TOSLINK) inputs. The USB interface works in device mode, receiving audio from a computer, while the optical input carries SPDIF signals. A USB isolator (ADUM4160) provides galvanic separation to prevent noise from the computer. Incoming digital audio streams are converted to PCM via USB-to-I2S (PCM2707) and SPDIF-to-I2S (CS8416) converters. A multiplexer selects the audio source, and an asynchronous sample rate converter (SRC4193) handles resampling and bit-depth conversion before sending the data to the PCM1792 DAC. Design Notes: USB and TOSLINK inputs for versatility Ground isolation via USB isolator Multiplexer required due to converters lacking tri-state outputs SRC4193 handles both resampling and clock synchronization TPA6120 provides high-current headphone drive References / Source: This project is based on my MSc thesis: https://github.com/sylwekkominek
