HHO plate design
A project log for A Safe(r) HHO gas carburetor for small engines.
No more gas, diesel, or propane. Run it on WATER!
thethriftstorehackerTheThriftstoreHacker 04/25/2017 at 18:050 Comments
I have messed around with the plate design of the mini HHO generator cells. I was thinking that large stainless steel washers would work but i need more surface area. I think the cells will be built out of thin stainless steel in a 7 plate configuration to minimize heat and get more production per cell. After i finish the first cell i will do a YouTube video measuring the production amounts.
