The complete assembly
A project log for ESP32 HF QRP FT8 Transceiver
A compact digitally controlled RF 1.8 to 28 MHz platform for HF amateur. DSP mod/demod and integrated FT8 QSO management.
guido-iw5alzGuido - IW5ALZ 04/11/2026 at 15:050 Comments
After finishing the RF amplifier and mounting it on the inner side of the aluminium box top, I can say the hardware assembly is quite consolidated.
The RF amplifier is on the left, with the two RD16HHF1 in push pull screwed directly on the inner side of the cover (below the perfoboard).
