A new challenge: Ethernet
05/07/2026 at 09:35 • 0 commentsThe whole transceiver is enclosed in a 1.5 mm aluminium box, which is very good for EMI shielding but very bad for the WiFi link. When I shut the cover, WiFi signal level drops down and becomes unstable.
I guess two options:
- an external WiFi antenna (pretty easy)
- an Ethernet link (pretty daunting)
An almost perfect FT8 sequence
04/27/2026 at 07:38 • 0 commentsAbout 15 days ago I succeeded to follow this almost correct FT8 sequence, but it had a few issues.
Issue
I decoded HB9DGZ answer -05 at 20:05:37 but its transmission was since 20:05:15 till 20:05:27 (my decoding took 10 seconds).Therefore (waiting for the even slot) I could plan to send R+06 only 1 minute later, since 20:06:30 till 20:06:42.
In the meantime HB9DGZ, not seeing my reply, correctly retried answer -05 since 20:06:15 till 20:06:27 which I decoded at 20:06:36.
At last, at 20:06:30 till 20:06:42 I transmitted R+06
Promptly, HB9DGZ decoded R+06 and transmitted RR73 since 20:06:45 till 20:06:57, which I decoded 7 seconds later at 20:07:04
My upgraded sequence
I answered SV9TLU transmitting JN53 since 9:33:00 till 9:33:12
At 9:33:15 SV9TLU transmitted -06 to me since 9:33:15 till 9:33:27
I decoded -06 before 9:33:30 so I could answer R+06 since 9:33:30 till 9:33:42
Final consideration
Since last SV9TLU CQ (at 9:32:57) till its RR73 (at 9:33:57) elapsed only 1 minute
To see my software improvements, see my my Github -
Correct FT8 QSO sequence
04/13/2026 at 18:19 • 0 commentsAfter a few attempts I was able to follow a correct FT8 QSO sequence, as you can see here.
The complete assembly
04/11/2026 at 15:05 • 0 comments
After finishing the RF amplifier and mounting it on the inner side of the aluminium box top, I can say the hardware assembly is quite consolidated.![]()
The RF amplifier is on the left, with the two RD16HHF1 in push pull screwed directly on the inner side of the cover (below the perfoboard).
From the Hawaii
04/06/2026 at 18:44 • 0 comments20260406 20:48:00 CET
With this receiver connected to my 10-160m mutilband End Fed Long Wire antenna I can receive a lot of FT8 spots from all over the world.
I was the only one, in Europe, to receive a message from KH6DL over the last 24 hours.
My antenna is nothing special as it's located at about 6 meters from the ground, between some buildings. Therefore I think my receiver is not so bad! -
My FT8 transmitter works!
03/28/2026 at 09:45 • 0 commentsMar 28th 2026
This morning I tested a single CQ IW5ALZ JN53 transmission (8W) and I got:![]()
FT8 QSOs Manager
03/27/2026 at 14:37 • 0 commentsIn the web portal I added a spot (on the left) and QSO (on the right) decoder:
(TODO) You could answer a CQ directly pushing Answer CQ.
Power Amplifier
03/13/2026 at 17:53 • 0 commentsI start from the SI5351 CLK2 signal, which is a (more or less) square wave with an amplitude around 3 Vpp.
At the moment I've built a 0.5 - 1 W amplifier (1-30 MHz 0.5-1 Watt class C amplifier) which works pretty well, but I'd like to reach 5 Watts at least.
For this reason I'd like to replicate this schematic![]()
that I found here 20w-broadband-hf-1-55mhz-power-amplifier.I modified only the voltage control part, using 2 bjt's instead of 2 MOSFET's because I have no P channel MOSFET.
Guido - IW5ALZ
