layout
A project log for USBpwrME
A handy adaptor to connect USB powered devices to a bench power supply for lab and test purposes!
ks-elektronikdesignKS-Elektronikdesign 03/17/2026 at 13:490 Comments
I have done a lot tests en verified the functions. most of the design work as intended. I also designed the layout to decrease the current path resistance as much as possible and managed to make a 2 layer board and it worked perfect. Then i decided that the orange OVP warning LED is really handy so i was forced to go up to 4 layer board to make that work :)
