Program 1. TV Show Folder Structure Setup Tool. This program will go to the web site called TV Maze and collect the TV show are and tag info and create the folder structure needed for a streaming server.
Program 2. You select the folder that contains the place holder folders (.txt files). Select the folder that contains the actual videos. Their name needs to be titled S01E01 for season 1 and episode 1. Once you have the two folders selected you then click on the preview map button and the list box will show you which files were found and what ones were not.
Details
Both these programs were written and developed in C#.
Files
