• Logs
    Emre03/29/2026 at 09:06 0 comments
    [32]HELLO! BOOT0 is starting!
    [34]BOOT0 commit : adaf1174cc
    [37]set pll start
    [39]periph0 has been enabled
    [42]set pll end
    [43][pmu]: bus read error
    [46]board init ok
    [48]ZQ value = 0x2e
    [50]get_pmu_exist() = -1
    [52]ddr_efuse_type: 0xa
    [54]trefi:7.8ms
    [56][AUTO DEBUG] single rank and full DQ!
    [60]ddr_efuse_type: 0xa
    [62]trefi:7.8ms
    [64][AUTO DEBUG] rank 0 row = 13
    [67][AUTO DEBUG] rank 0 bank = 4
    [71][AUTO DEBUG] rank 0 page size = 2 KB
    [74]DRAM BOOT DRIVE INFO: V0.33
    [77]DRAM CLK = 528 MHz
    [79]DRAM Type = 2 (2:DDR2,3:DDR3)
    [83]DRAMC read ODT  off.
    [85]DRAM ODT off.
    [87]ddr_efuse_type: 0xa
    [89]DRAM SIZE =64 M
    [91]dram_tpr4:0x0
    [93]PLL_DDR_CTRL_REG:0xf8002b00
    [96]DRAM_CLK_REG:0xc0000000
    [98][TIMING DEBUG] MR2= 0x0
    [103]DRAM simple test OK.
    [105]dram size =64
    [107]card no is 0
    [109]sdcard 0 line count 4
    [111][mmc]: mmc driver ver 2021-04-2 16:45
    [120][mmc]: Wrong media type 0x0
    [123][mmc]: ***Try SD card 0***
    [132][mmc]: HSSDR52/SDR25 4 bit
    [135][mmc]: 50000000 Hz
    [137][mmc]: 1936 MB
    [139][mmc]: ***SD/MMC 0 init OK!!!***
    [205]Loading boot-pkg Succeed(index=0).
    [208]Entry_name        = opensbi
    [211]Entry_name        = u-boot
    [215]Entry_name        = dtb
    [218]mmc not para
    [219]Jump to second Boot.
    OpenSBI auto-t113-linux-V0.8-1-g771d82e
       ____                    _____ ____ _____
      / __ \                  / ____|  _ \_   _|
     | |  | |_ __   ___ _ __ | (___ | |_) || |
     | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | |
     | |__| | |_) |  __/ | | |____) | |_) || |_
      \____/| .__/ \___|_| |_|_____/|____/_____|
            |_|
    Platform Name          : T-HEAD Xuantie Platform
    Platform HART Features : RV64ACDFIMSUVX
    Platform Max HARTs     : 1
    Current Hart           : 0
    Firmware Base          : 0x41fc0400
    Firmware Size          : 75 KB
    Runtime SBI Version    : 0.2
    MIDELEG : 0x0000000000000222
    MEDELEG : 0x000000000000b1ff
    PMP0    : 0x0000000041fc0000-0x0000000041fdffff (A)
    PMP1    : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
    PMP2    : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
    PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒
    U-Boot 2018.05-g2a1965a (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
    [00.305]DRAM:  64 MiB
    [00.307]Relocation Offset is: 01ed9000
    [00.311]secure enable bit: 0
    [00.314]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
    [00.320]flash init start
    [00.322]workmode = 0,storage type = 1
    [00.326][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
    [00.331][mmc]: get sdc_type fail and use default host:tm1.
    [00.337][mmc]: can't find node "mmc0",will add new node
    [00.342][mmc]: fdt err returned <no error>
    [00.346][mmc]: Using default timing para
    [00.350][mmc]: SUNXI SDMMC Controller Version:0x50310
    [00.367][mmc]: card_caps:0x3000000a
    [00.370][mmc]: host_caps:0x3000003f
    [00.374]sunxi flash init ok
    [00.376]line:703 init_clocks
    [00.379]drv_disp_init
    request pwm success, pwm7:pwm7:0x2000c00.
    fdt get node offset faill: hdmi
    [00.397]unable to map hdmi registers
    [00.400]drv_disp_init finish
    [00.407]Loading Environment from SUNXI_FLASH... OK
    [00.432]boot_gui_init:start
    [00.435]set disp.dev2_output_type fail. using defval=0
    [00.442]boot_gui_init:finish
    partno erro : can't find partition bootloader
    partno erro : can't find partition boot-resource
    [00.454]Get bootloader and boot-resource partition number fail!
    [00.460]out of usb burn from boot: not need burn key
    [00.465]Item0 (Map) magic is bad
    [00.468]the secure storage item0 copy0 magic is bad
    [00.473]Item0 (Map) magic is bad
    [00.476]the secure storage item0 copy1 magic is bad
    [00.480]Item0 (Map) magic is bad
    partno erro : can't find partition private
    root_partition is rootfs
    [00.491]update part info...
