Logs
A project log for Too Fast & Too Furious - Allwinner F133
Ultra-minimal, lightning-fast Linux for F133 RISC-V. Optimized for 64MB RAM, open-source, and ready for low-power embedded edge projects.
emreEmre 03/29/2026 at 09:060 Comments
[32]HELLO! BOOT0 is starting!
[34]BOOT0 commit : adaf1174cc
[37]set pll start
[39]periph0 has been enabled
[42]set pll end
[43][pmu]: bus read error
[46]board init ok
[48]ZQ value = 0x2e
[50]get_pmu_exist() = -1
[52]ddr_efuse_type: 0xa
[54]trefi:7.8ms
[56][AUTO DEBUG] single rank and full DQ!
[60]ddr_efuse_type: 0xa
[62]trefi:7.8ms
[64][AUTO DEBUG] rank 0 row = 13
[67][AUTO DEBUG] rank 0 bank = 4
[71][AUTO DEBUG] rank 0 page size = 2 KB
[74]DRAM BOOT DRIVE INFO: V0.33
[77]DRAM CLK = 528 MHz
[79]DRAM Type = 2 (2:DDR2,3:DDR3)
[83]DRAMC read ODT  off.
[85]DRAM ODT off.
[87]ddr_efuse_type: 0xa
[89]DRAM SIZE =64 M
[91]dram_tpr4:0x0
[93]PLL_DDR_CTRL_REG:0xf8002b00
[96]DRAM_CLK_REG:0xc0000000
[98][TIMING DEBUG] MR2= 0x0
[103]DRAM simple test OK.
[105]dram size =64
[107]card no is 0
[109]sdcard 0 line count 4
[111][mmc]: mmc driver ver 2021-04-2 16:45
[120][mmc]: Wrong media type 0x0
[123][mmc]: ***Try SD card 0***
[132][mmc]: HSSDR52/SDR25 4 bit
[135][mmc]: 50000000 Hz
[137][mmc]: 1936 MB
[139][mmc]: ***SD/MMC 0 init OK!!!***
[205]Loading boot-pkg Succeed(index=0).
[208]Entry_name        = opensbi
[211]Entry_name        = u-boot
[215]Entry_name        = dtb
[218]mmc not para
[219]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-1-g771d82e
   ____                    _____ ____ _____
  / __ \                  / ____|  _ \_   _|
 | |  | |_ __   ___ _ __ | (___ | |_) || |
 | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | |
 | |__| | |_) |  __/ | | |____) | |_) || |_
  \____/| .__/ \___|_| |_|_____/|____/_____|
        |_|
Platform Name          : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs     : 1
Current Hart           : 0
Firmware Base          : 0x41fc0400
Firmware Size          : 75 KB
Runtime SBI Version    : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0    : 0x0000000041fc0000-0x0000000041fdffff (A)
PMP1    : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2    : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒
U-Boot 2018.05-g2a1965a (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
[00.305]DRAM:  64 MiB
[00.307]Relocation Offset is: 01ed9000
[00.311]secure enable bit: 0
[00.314]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.320]flash init start
[00.322]workmode = 0,storage type = 1
[00.326][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.331][mmc]: get sdc_type fail and use default host:tm1.
[00.337][mmc]: can't find node "mmc0",will add new node
[00.342][mmc]: fdt err returned <no error>
[00.346][mmc]: Using default timing para
[00.350][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.367][mmc]: card_caps:0x3000000a
[00.370][mmc]: host_caps:0x3000003f
[00.374]sunxi flash init ok
[00.376]line:703 init_clocks
[00.379]drv_disp_init
request pwm success, pwm7:pwm7:0x2000c00.
fdt get node offset faill: hdmi
[00.397]unable to map hdmi registers
[00.400]drv_disp_init finish
[00.407]Loading Environment from SUNXI_FLASH... OK
[00.432]boot_gui_init:start
[00.435]set disp.dev2_output_type fail. using defval=0
[00.442]boot_gui_init:finish
partno erro : can't find partition bootloader
partno erro : can't find partition boot-resource
[00.454]Get bootloader and boot-resource partition number fail!
[00.460]out of usb burn from boot: not need burn key
[00.465]Item0 (Map) magic is bad
[00.468]the secure storage item0 copy0 magic is bad
[00.473]Item0 (Map) magic is bad
[00.476]the secure storage item0 copy1 magic is bad
[00.480]Item0 (Map) magic is bad
partno erro : can't find partition private
root_partition is rootfs
[00.491]update part info
[00.494]update bootcmd
[00.497]change working_fdt 0x42a98da0 to 0x42a78da0
disable nand error: FDT_ERR_BADPATH
[00.507]The storage not support sample function
No reserved memory region found in source FDT
[00.532]update dts
noncached_alloc(): addr = 0x42b02a40
noncached_alloc(): addr = 0x42b02a80
noncached_alloc(): addr = 0x42b02ac0
noncached_alloc(): addr = 0x42b03300
geth_sys_init:639: get node 'gmac0' error
geth_sys_init fail!
[00.552]Board Net Initialization Failed
[00.555]No ethernet found.
Hit any key to stop autoboot:  0
FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1
[00.632]LCD open finish
[00.993]no vendor_boot partition is found
Android's image name: f133-mq_r
Detect comp none
[01.010]
Starting kernel ...
[01.013][mmc]: MMC Device 2 not found
[01.016][mmc]: mmc 2 not find, so not exit
